Oy, if it's not one thing, it's another...
![Roll Eyes ::)](http://forums.sohc4.net/Smileys/default/rolleyes.gif)
Here's the bike:
'76 CB550k, 30k miles, K&N pods, 4-2 open turnouts. Was jetted to 118, now 109. (see below). Aftermarket chrome coils, stock points.
Here's the situ:
Engine was running well, but bogged at WOT due to over-large main jets. It started seeping oil, so I tucked in and found out the head wasn't properly torqued, so in between stripping and helicoiling holes, I cleaned the combustion chambers (carbon fouled), and cleaned up the casting marks in the intake and matched the ports to the manifolds.
Reinstalled and retorqued the head, making SURE to keep the cam timed properly to the crank. I reinstalled the rocker assembly and reset the valves, put the pipes back on with all new exhaust gaskets. While the carbs were off, I rejetted from 118 (#56 drill) to 109 (#57 drill). Cleaned the carboned plugs and regapped to 0.030" (range is .028-.034", I think they had been at .025"). Put everything back together, and kicked myself raw trying to start it. Tried the elec starter, but the battery was really low (it had drained just sitting for a week with no connections on it, go figure), so it didn't help.
I charged the batt overnight, and tried it again this morning. I can't get it to start without full choke and FULL THROTTLE. When it kicks over, since it's at full throttle, it revs WAY up, but seems to be running only on the left side and just sporadically on the right. As a result, the engine is vibrating some, not happy. As soon as I back off the throttle a bit, it dies. Sided-ness running is validated by a quick thumb on the pipes- left two are hot, #4 is cool, #3 is DEAD cold.
Haven't had a chance to check the plugs, but the only things I can think of are: Improper valve clearance, bad coils, or blocked carbs. The carbs were only open long enough to swap out the jets, and nothing else was changed or adjusted. Valves were done by the book, I don't know why I'd suspect them, but I'll double-check just in case. The coils seem to have a reputation of having weak primary windings, I suppose it's possible they chose this time to give up the ghost, I'll ohm them out and report back later.
In the meantime, anyone got any suggestions of what else to check?
Thanks,
