Author Topic: For all your Washer / O-ring "Rubber" or Felt Needs  (Read 2187 times)
Offline coolcat2002
« on: May 15, 2007, 07:24:36 AM »
I read some restorer that said to use Neoprene instead of felt washer (like in our Swingarm).  I figure, who the heck uses felt/ leather type washers anyhow??  But it was hard to buy just one o-ring or just one washer.  I had to find a place where was no minimum!!
Finally I found it:
http://www.smallparts.com/
If you want to know the difference between materials of Neoprene, Viton, Silicone, Buna, etc.:
http://www.allorings.com/material_selection.htm
There some grommets there too.
Of course yall know about: http://www.vintageconnections.com/GrommetKit.htm
The gasket set that  bought from http://www.cmsnl.com/ sucks it was made by KP and it was missing the tappet o-rings.  I will complain to them.
« Last Edit: May 15, 2007, 07:35:01 AM by coolcat2002 »
Offline rhinoracer
Re: For all your Washer / O-ring "Rubber" or Felt Needs
« Reply #1 on: May 15, 2007, 07:32:00 AM »
Valuable info, thanks.
Baja native.
Offline DrMark
« Reply #2 on: May 15, 2007, 09:17:41 AM »
Where's the best place to get the grommets for the side covers? Looking to replace the grommets on my 1978 CB550K.
1978 CB550K
1983 CB650SC Nighthawk
« Reply #3 on: May 15, 2007, 10:50:30 AM »
You mean, besides the Honda dealer?
Offline DrMark
« Reply #4 on: May 15, 2007, 11:16:02 AM »
Local Honda Dealer wanted big money for those grommets. Figured there might be a source that is more reasonable. If not, I guess I'll order thru local dealer. Thanks TT.
1978 CB550K
« Reply #5 on: May 15, 2007, 11:24:33 AM »
Philosophical point to consider:
Do you think Honda will still offer parts for the old bikes if they don't sell enough of them?
Offline merc2dogs
« Reply #6 on: May 15, 2007, 11:55:41 AM »
 Pull out the grommet and take it to an electronics supply, the type that handles control boxes etc for industrial equipment.
 they can match up a wire grommet to it, may not -be- oval, but it's rubber and will conform.
  My old bike had a grommet from an air compressor at work that just happened to fall off while I was rebuilding the pressure switch.  perfect size
ken.
Offline .RJ
  • homebase in your airspace
« Reply #7 on: May 15, 2007, 11:59:05 AM »
Bikebandit.com - I've bought most of my OEM parts there.  I think the new felt things and dust caps were a few bucks for my 750.
Offline coolcat2002
« Reply #8 on: May 16, 2007, 10:04:52 AM »
UPDATE: CSMNL just told me their "complete" gasket kit doesn't come with the 8 tappet cover rings.  Does that suck or what???
About $2.50 each @ motogrid.com for OEM.
Customer service said they would mail 8 of them to me because I didn't know.  So they are nice people.
« Last Edit: May 25, 2007, 09:58:34 AM by coolcat2002 »
