uh-oh.
The following is the opinion of one man and does not represent the position of this website or any country, creed, religion, or race.
OK, you can use any motorcycle oil you want: synthetic, refined crude, or blended. Use the weight grade specified in the owners manual for the expected temperature outside. It should specify multigrade, if not use a multigrade that brackets the weight of the oil suggested - if it's SAE 20, use SAE 10-30
There are serious issues with using any car oil, avoid them. The additives for car oils change regularly, identical brand and weight can be a different oil tomorrow. Current car oils have almost eliminated certain friction modifiers known to contaminate some catalytic converters, and added others that may cause problems with wet clutches. The friction modifiers they are reducing are important for SOHC4 engines with their flat cam followers; the cams and followers can wear out quite fast, especially new parts that haven't worn smooth together yet. A car oil touted as superb for our bikes today might be reformulated tonight because of changed regulations, chemical prices, phrenological advice to the head chemist, or whatever - and they WILL NOT be considering how it will work in old motorcycle engines.
Motorcycle specific oils, so far, have additive packages that work with flat followers and don't hurt wet clutches.
You can also use diesel rated oil, diesel engines need the extra friction modifiers to keep the piston pins from wearing out immediately from the high compression load - as long as it doesn't have molybdenum disulphide added (bad for your clutch). Either refined crude, synthetic, or blended is fine again. Shell Rotella T Synthetic has been reported to be an excellent choice.
