Author Topic: ...adjusting choke idle...(78 cb750F)  (Read 1565 times)
Offline Lumbee
    • My pics...
« on: June 26, 2005, 07:53:21 AM »
...do I adjust the choke idle with the screw located around the bowls?  If so which way (in/out) moves the idle up or down?
"I'm not a welder, but I play one on HondaChopper.com"
Offline Lumbee
    • My pics...
Re: ...adjusting choke idle...(78 cb750F)
« Reply #1 on: June 26, 2005, 01:31:41 PM »
...think I figured it out...I just adjusted the height of the cable for the choke, so it pulls the choke up a little farther...   ::)
eldar
« Reply #2 on: June 28, 2005, 01:55:17 PM »
I lowered my cable so that the little clamp is actually on the plastic cable cover. I am sure my carbs are not completely correct on assembly for the choke actuation but it works fine and gives me no grief!
Offline Lumbee
    • My pics...
« Reply #3 on: June 28, 2005, 02:00:51 PM »
...yea, I'm rebuilding another set of 78 Carbs and the choke rod is a comlete Bi-Atch!!!  It will be a few months b4 I get to try them out, but I'm keeping my fingers crossed...
