You gotta love it when things go right! After months of studying the service manual and every carb post question I could find on SOHC4, I finally ripped the 022A carbs out of my '74 CB550 to rebuild. Before rebuilding, the throttle would stick, wouldn't idle reliably, flood and dump fuel. It was very hard and embarrasing to ride. lol
Anyways, I bought some K&L carb kits and took the last rainy week to tear down, clean and rebuild. Of course, I followed the instructions provided here by first replacing the air filter, doing the valve adjustments, timing, spark plug gap check/replace, cam chain tension, etc.
I probably spent 5 hours on cleaning alone (over a course of a couple of nights). There was a heavy, heavy varnish throughout the carbs and the brass jets, etc were in really rough shape. I took pictures throughout the process so I could refer to them afterwards in case I got into trouble.
The nearest Canadian NAPA dealer wouldn't sell me SeaFoam (He had it, but wouldn't sell it to me), so after telling him off, I soaked the parts in Varsol for a day or two and then used PJ1 carb cleaner to spray/brush out the varnish and the air passageways. It cleaned them pretty good though. I used compressed air to blow out anything else that was loose in the carbs.
The floats were set way too high (25mm to 30mm) so I brought them back to spec (22mm). Assembling was fast, probably 2 hours, with the most frustrating part being the round bowl gaskets. (Found a tip on here saying to tack the gasket corners with scotch tape, screw down the bowls until the gaskets barely touch the carb bodies, then pull out the tape out carefully and tighten bowls down. It worked good - no leaks. Replaced every part with the stuff the K&L kits came with.
Anyways, got the carbs bench synced, mounted and synchronized with my new Carbtune II and she runs like a friggin top! Just like a new bike! The wife jumped on the back for the first time last night and we went out on the highway to a small town cafe. It purred like a kitten and didn't miss a beat. I have to say if anyone is considering rebuilding carbs, its easy, just follow this sites directions step by step without taking shortcuts, and you could save yourself hundreds and have the satisfaction of learning how to tune your own ride.
Anyways - thanks to everyone here for providing me with the info to help keep this old bike on the road! See you later - I'm going for a rip!
javascript:void(0);
