Author Topic: Honda Brake Shoe Supplier/dealers FOUND!!!  (Read 9743 times)
tbone
Re: Honda Brake Shoe Supplier/dealers FOUND!!!
« Reply #25 on: May 31, 2007, 06:46:14 PM »
No  problem Puppy!
When I read your dilemma I said to myself, "self, somebody out there has got to have a set of these"!  ;D ;)
glad you were able to get them!
Oh, and, keep'er shiny side will ya!  :P
Offline GNXFan
« Reply #26 on: June 01, 2007, 04:26:14 AM »
I too have used Retrobikes in the past when I was restoring either CT70s or small single cylinder Hondas. They used to actually send you the part first and trust you to pay them on the honor system but no more. They got burned. Not a lot of parts for our bikes but good people to deal with anyway.
Offline puppytrax
« Reply #27 on: June 11, 2007, 05:55:10 AM »
Just a quick follow-up...I mounted one set of the Vesrah VB-128 shoes from Dennis Kirk on the rear of my daily-driver CL450 yesterday...no problem fitting them on...the pivot holes in the aluminum were quite, ah, shall we say, "ample"...    :-\
I was somewhat annoyed, as the OEM Honda shoes fit nice and snug on the pivots...not tight, but there was no play in them...
A half-hour test ride didn't really show up any great increase in stopping power...but as Bryanj pointed out, they need "bedding in"...(there is actually a technique for this that I've used on my Corvette, but I doubt Honda ever did anything like that to their Customer Serviced bikes)...   ::)
Doing the twin-leading front shoes today...I hope...   :P
Update: I got the Vesrah VB-117 dual-leading shoes installed today. Nothing unusual; except the pivot holes were as sloppy as the rears. The adjustment rod gave me some frustration; with two shoe springs, the outer helper spring, and the cable spring all pulling on the actuating cams, it was impossible to "feel" the rear shoe touching the drum. So, I milled the heads off the peened-on clevis pins, made up a pair of new 6mm SS clevis pins drilled for Cotter pins, and then installed the brake assembly, hub/wheel, speedo drive, and axle and "bench synchronized" the shoes by holding the front actuator/shoe against the drum; pushed the rear actuator/shoe against the drum also, and adjusted the rod so that the two new pins just slid right in...
Worked great! Took it out for a spin; better braking than the old shoes, but until they "bed in", I won't see any dramatic difference in stopping.
The OEM adjusting rod was disappointing; I expected better engineering from Honda. No flat on it; no hex; no knurling...nothing to get a grip on to turn it...   >:(
« Last Edit: June 11, 2007, 05:13:29 PM by puppytrax »
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
