Ah, success..............
Sure enough, #2 idle circuit was clogged - the jet was kosher, but the passageway into the "body" was clogged - a bit of air took care of things.
Adjusted the mix screws to 1.5 turns out, and reassembled.
Voila! Runs MUCH better - but I'm still not happy with how it idles - still seems a bit rough when I try to get it to idle at 1050-1100 (what I've read it should idle at).
It behaves much nicer at 1400-1500, so I'm not really sure if I should leave well enough alone, or attempt additional surgery.
Also, still getting some "popping" sometimes while running down the road at constant RPM (4-5K).
I noticed something else last night - with bike idling in neutral, and clutch engaged, I hear a little noise. Pull in the clutch, it goes away. let it out, and rev to 2K RPM, and the noise seems to go away as well.
What gives?
