Author Topic: Todays carb/jet/starting question-updated  (Read 1581 times)
Offline hondachopproject
« on: June 05, 2007, 05:14:14 PM »
I am sure This has been asked before, but anyways.
To start with working with 76 cb550, open pipes, K&N Uni-Filters, 125 main Jets.
Last summer had hard time starting bike, with choke closed.
Bike starts easly with choke OPEN, engine races very fast and then back fires or pops after starting, choking engine slows idle. BUT choking to much kills engine. While riding I have to open choke enough to get engine to run (although fast), and slowly close choke to slow idle so that it is half way safe to ride.
I have only ridden VERY short distances.
Does anyone know what to do to solve this problem?
HELP.
Thanks,
Lee
« Last Edit: June 07, 2007, 03:14:42 PM by hondachopproject »
92 HERITAGE
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Todays carb/jet/starting question
« Reply #1 on: June 05, 2007, 05:23:44 PM »
125's sound huge for a 550, even with open pipes and a K&N. What do your plugs tell you?
No.
« Reply #2 on: June 05, 2007, 05:50:42 PM »
I have not checked them yet.
92 HERITAGE
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #3 on: June 05, 2007, 05:55:38 PM »
No.
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #4 on: June 05, 2007, 06:16:41 PM »
I'm running a 76 550 engine / carbs with 105s and it barely takes a choke unless it's hella cold out.  Just my 2 cents.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
« Reply #5 on: June 05, 2007, 06:34:58 PM »
Check 'em.
Could I learn much from them as I put them last summer -but bike was not rideable at the time.
When I would try to get the bike started at that time the would often foul out.
It wasn't until yesterday after putting engine back in frame that I accidently found it would easly start with choke open.
92 HERITAGE
« Reply #6 on: June 05, 2007, 06:35:50 PM »
what are you running for exhaust and air cleaner? think the 125 is too big?
92 HERITAGE
« Reply #7 on: June 05, 2007, 07:39:03 PM »
I'm running stock airbox and exhaust and about 1 1/2 turns our on the idle mix.  Fires right up with about half choke when it's cool and goes quickly to full open.  I'd look into getting some smaller jets but like mlinder said, you got to put some fresh plugs in and check them to know for sure.
Re: Todays carb/jet/starting question-updated
« Reply #8 on: June 07, 2007, 03:17:55 PM »
I put new plugs and ran her just down the rode and back.
I still needed to play with choke to get it to run correctly.
After pulling the plugs, they were dry and black sooty collored.
Where do I go from here? ???
125 jet too much?
92 HERITAGE
« Reply #9 on: June 07, 2007, 04:14:07 PM »
First, I'd go to the FAQs section and look at the carb tuning thread.  There's tons of great info there and it'll get you going.  Once you've got that down, see where you are.  I bet you have a few hundred miles on her before you've tried everything that's listed.
