Author Topic: 350f Headlight options. Size needed.  (Read 1789 times)
asmallsol
« on: June 05, 2007, 08:13:12 PM »
As you all know, the stock cb350F headlight sucks and needs attention if you ever plan on doing any riding at night. I want to convert to an H4 bulb setup, and then convert to an HID setup. I can get it done for under $200 and I think that it would be a great improvement to the bike.
Anyways I have been doing some searching and was wondering, what is the exact size of our headlights. I have been doing some reading and some people say its just a little bigger then 6 or somewhere in there, but no exact measurements.
I took my headlight apart to try and measure it, but trying to measure a curved surfice with a tape measure doesn't really work too well.
As for the things I was looking at....
http://www.classicgarage.com/he-70476b.html   and
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320118540957&sspagename=ADME:L:RTQ:US:1
I emailed the above seller on ebay and he said he could do a motorcycle kit for a reasonable price.
Offline Gordon
  • 750K1, 550K2
Re: 350f Headlight options. Size needed.
« Reply #1 on: June 05, 2007, 10:27:26 PM »
Someone correct me if I'm wrong, but I believe the 350 and 400 have a 5 3/4" headlight.  Dennis Kirk has the H4 conversion in that size for $37.  I think if you go that route, you'll forget about doing the HID conversion.  I have the 7" H4 on my 750, same bulb as the 5 3/4 (60/55w), and it's at least as bright as the headlights on my car.
Offline Bodi
« Reply #2 on: June 06, 2007, 11:56:32 AM »
It's an oddball size, 5 3/4" sounds about right. From my limited research they are only used on the 350-4, 400F, and Yamaha RD350.
You can get a H4 unit that fits, Cibie dealers can probably order them or DSS has some in stock - I don't know their brand.
The Cibie one I have comes with a bogus mounting system and I ended up just gluing it in the chrome ring with silicon - looks OK. maybe the DSS ones have the ears to use the original mounting system. I haven't missed the left/right adjustability though.
Good luck fittng a HID kit in the headlight shell though - the  hi/lo beam ones are pretty large in back with the shifter mechanism. Fitting all the wires and the stock headlight in there is a trick already.
asmallsol
« Reply #3 on: June 06, 2007, 06:34:06 PM »
anyone with a little more confidence in the size?
Offline gtyler5
« Reply #4 on: June 06, 2007, 06:47:47 PM »
JC Whitney has a 5 3/4 inch H4 kit for $17.99 they seem to have the best price on these kits, also have a 7" for $18.99. It seems like it would be one of these two sizes they are the standards, but I am only familar with the 750's and they are 7".
1976 CB750F cafe
1978 CB750F (in progress)
1993 CB750 Nighthawk
asmallsol
« Reply #5 on: June 06, 2007, 07:08:07 PM »
lol, thats not to convincing.
« Reply #6 on: June 07, 2007, 01:17:47 AM »
My very aged and overworked brain tells me that the Honda CB400 and the Yamaha RD were the same size and neither of the two car "standards" fits. As I remember it only Cibie did an aftermarket H4 for them and I havent seen one of those for many a year. If Dave Silver lists them i would grab one quick before they vanish
asmallsol
« Reply #7 on: June 07, 2007, 07:45:18 PM »
If that is the case, has anyone switched out to a different bucket, either a 5 3/4's or a 7incher?
« Reply #8 on: June 08, 2007, 12:31:19 AM »
possibly but you would have to bend the expensive and unobtaiium headlamp ears
Offline Bodi
« Reply #9 on: June 08, 2007, 08:35:18 AM »
There's a posting http://www.sohc4.us/forums/index.php?topic=22513.0 with Cibie (sibie?) headlights. He doesn't specify if they are for the 750 or 350/400, but you can ask him. The price is right, shipping from the UK might hurt.
tmht
« Reply #10 on: June 08, 2007, 10:00:17 AM »
The 350 and the 400 are 6 1/2" headlights. At least the 400 doesn't use the spring clips to hold the light to the rim, it uses two screws that go into tabs that are actually attached to the bulb. Your best bet in this situation is going to be to look for a generic sidemount 5 3/4" or 7" bucket and h4 set up. I think I have seen them around in various locales for less than $40.
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: June 08, 2007, 10:51:17 AM »
The 5 3/4" bucket would probably fit without having to bend the headlight ears.  Maybe put a couple of thick washers on either side to make up most of the difference.
asmallsol
« Reply #12 on: June 08, 2007, 05:55:16 PM »
Well the thing is, it doesn't matter what size the bucket is to fit a whole new bucket on the bike, its a question of the width of the mounting points on the bucket and the bike. If its a bigger bucket, (assuming its parabolic like the current one) then the lens is just going to be further out front. Smaller, would be more resessed, assuming its a universal that you would have to drill to make fit (which leads to poor alignment, which I would like to avoid that route).
Would say a CB750 7incher bucket fit between our mounting tabs (I eyeballed it to be 6 inches with out taking the headlight off)
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
« Reply #13 on: June 08, 2007, 06:20:48 PM »
My CB350 twin uses the 5 3/4 and My 400f uses something like the 6.5 that was stated.I know its a little bigger than the 350. I would guess you have a 6.5 inch on your 350f.
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
