Support the site. Your contributions keep this site running.
sorry there is no number posted, would that petcock be on any other bikes? i can check that way
Quote from: snyquist53 on June 05, 2007, 09:19:48 PMsorry there is no number posted, would that petcock be on any other bikes? i can check that wayyes all the 83 cb650's use it as do the dohc 750 and 900 from 80-84
The part number was whatever was listed at the dealer on their fiche. It cost about $50 and came with the filter. May have been a 16950-461-771 as listed at www.crotchrocket.com under 1981, cb650c, fuel tank. The filter alone is $30 to buy seperate so your only paying $20 for the petcock. Too bad it isn't available seperate. By the way, saw your build thread, looks good. I will have to get around to posting mine. I do have a used spare petcock without the filter, you can have it if you want it, just taking up room in my toolbox. You would be better off getting the new one with the filter and be done with it. -Dave
Works as far as I can tell. Never rode with it. does not leak and holds back fuel so.... Anyways, why do you need a high flow?, the OEM works fine IMO.
