Author Topic: clip position  (Read 1553 times)
Jeremy
clip position
« on: June 29, 2005, 04:56:51 AM »
Can I change my needle clip position of my carbs without removing them from the bike?
Have a 77 550k
Online bryanj
Re: clip position
« Reply #1 on: June 29, 2005, 08:29:24 AM »
Yes if you have a trained spider with a mechanical bent otherwise no.
Re: clip position
« Reply #2 on: June 29, 2005, 08:58:08 AM »
I have done so with a 74 CB550.  I know the 77 carbs are a bit different, though.  Number two carb might give you grief.  I'd probably try it.  If you can do #2, the rest ought to be easy.  What's the worst that can happen if you try?  Removing the whole carb bank?
Offline Bob Wessner
  • "Carbs Suck!"
Re: clip position
« Reply #3 on: June 29, 2005, 10:03:04 AM »
This is the one single advantage to the old 750 K0 carbs with the four individual throttle cables. Just pop the caps off, slip out the slides and change the needles or clips, just had to do it. Beyond that though, they are something of a pain.  >:(
eldar
Re: clip position
« Reply #4 on: June 29, 2005, 05:48:51 PM »
gee I dont have to worry about it! but even with the carbs on my bike I could remove the slides if I really needed to. I think it would take longer than taking the bank off though. I may be almost as fast at that as Bob, but I dont think...nevermind Bob knows where I am going! ;D
