Author Topic: Goop in front of my Front Sprocket / Rear Transmission cover  (Read 1345 times)
Offline coolcat2002
As you can see, there's this epoxy looking brown (looks black) thing in front of my front chain drive sprocket.  I'm guessing at one time the chain broke and put a hole in there and the PO tried to patch it up?
Do yall have this goop so that incase this happens it protects the case?  How do you remove it?
eldar
Re: Goop in front of my Front Sprocket / Rear Transmission cover
« Reply #1 on: June 17, 2007, 02:41:49 PM »
You could probably use a dremel with a sander wheel or grind wheel to remove it.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: June 17, 2007, 03:04:29 PM »
Can I assume you want to remove it to have it welded?
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: June 17, 2007, 03:08:07 PM »
Ditto.
If it's sufficiently plugging a hole in the case, I wouldn't go messing with it unless you plan on doing something else to stem the flow of oil.
Offline coolcat2002
« Reply #4 on: June 17, 2007, 03:19:17 PM »
Damn it,  I should have checked before I bought this piece of junk.  I don't want no patched up hole in my engine.  I intended to split the cases but now I guess I'll just leave it.
