Author Topic: front sproket position and fit? <--- New question  (Read 2245 times)
Buffo
« on: June 29, 2005, 06:18:31 PM »
I have the famous 1978 CB750K8. When I got it the front sproket was off. On one of the sides it is raised a bit. Does that raised side got twards or away from the case?
Don
« Last Edit: July 01, 2005, 07:46:35 PM by Buffo »
Buffo
Re: front sproket position?
« Reply #1 on: July 01, 2005, 04:02:59 PM »
Anyone?
Does it matter?
Don
« Reply #2 on: July 01, 2005, 04:23:40 PM »
Don,
All the sprockets I have seen dont have a raised side, so you may have an aftermarket sprocket.
If you put it with the raised side away from the engine the chain will be a bit out of line.
Have the flat side face you then it should be the same alignment as the stock sprocket.
Good luck Don.
Sam Green.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: July 01, 2005, 04:26:07 PM »
This is from a K8/F3 manual, it doen't show any raised portion.
« Reply #4 on: July 01, 2005, 04:30:53 PM »
Totaly different to the early Ks then. ???
Buffo
« Reply #5 on: July 01, 2005, 04:41:50 PM »
Is the sproket suppose to be tight against the shaft it goes on after you tighten the bolt and washer or will it move a little bit?
I bought a new bolt from honda but they didnt sell the washer(s) any more. Is the washer(s) just a plain flat washer or is it special in some way. All i got with my bike was the sprocket so i have notheing to go an.
How many washers are there?
I bought a SS washer that fits the bolt but when i tighten it down the sproket moves a little bit. Not front to back like the direction of the chain but side to side...just a little.
So in other words it is held in place but not tight.
Don
Offline jotor
« Reply #6 on: July 01, 2005, 05:13:34 PM »
Uh, just a thought, but maybe the raised part of the sprocket replaces the washer.  Is the sprocket OEM?
Joe
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
Buffo
« Reply #7 on: July 01, 2005, 05:15:53 PM »
I have no Idea if it is OEM or not.
The bolt honda sold me is small and in no way could hold the sprocket without a waher of some osrt.
Don
Offline dpen
Re: front sproket position and fit? <--- New question
« Reply #8 on: July 01, 2005, 08:28:07 PM »
My K7 has the same setup.
Flat side of sprocket to engine.
Normal flat washer under the bolt. Use a bit of "Locktite" on the bolt.
The sprocket will move from side to side. This is adapted from trailbikes & allows the sprocket to find it's own place on the shaft depending on loading on the chain e.g. hard acceleration, slight mis-alignment of the rear wheel etc.
The setup looks flimsy but I've never heard of one coming off.
Buffo
« Reply #9 on: July 01, 2005, 09:38:19 PM »
Thanks gang!!!
One step closer to going down the road. ;D
Don
