i sold my '71 cb350 to a buddy a while back, and wouldn't you know it--it started having every problem in the book as soon as he got it...
i finally got around to supervising a total tuneup (points, condensers, point gaps, timing, valves, cam chain tension, carb clean and rebuild, and carb sync), but it still has a continuing problem. after adjusting the mixture screws and syncing the carbs and cables as per official honda instruction (and as a did countless time on that bike and several other cb or cl350's), it idles at a perfect 1000-1200 rpm.
however, after running around the block it jumps up to about 6000 RPM, and won't come down unless the kill switch shuts the bike down. kick it over again? perfect idle. we have sprayed starting fluid everywhere and have pretty much ruled out vacuum leaks, and two different sets of carbs have produced the same results. the plugs show a nice fat blue spark upon testing.
nevertheless, i can't help but feel like it's some ignition/ electrical issue causing a weaker detonation, that suddenly catches up and makes it run better than when setting everything up at idle.
has anyone else had this problem? poor guy is at his wit's end...
