Author Topic: Caliper Rattle  (Read 4965 times)
Offline crazypj
  • I'm brill, me
Re: Caliper Rattle
« Reply #25 on: July 28, 2007, 08:05:17 AM »
I think its 10mm, use 3/8" washers to shim.
 If its greased it helps to damp down movement a bit as well.
PJ
Offline Bob Wessner
  • "Carbs Suck!"
Re: Caliper Rattle
« Reply #26 on: July 28, 2007, 03:00:20 PM »
PJ
Thanks for the equivalent measurements. Checked on-line in a couple of places and if I was willing to buy them in 1,000 lots, they're readily available. ;D I guess I will go check some local hardware shops. :-\
Offline Bob Wessner
  • "Carbs Suck!"
Re: Caliper Rattle -- Solved
« Reply #27 on: August 08, 2007, 09:19:19 AM »
Well, after changing the fork oil yesterday and being embarrassed by complaining about out temps when others have to suffer through worse, I went back out to the garage to tackle the rattling caliper problem.
I had no luck finding shim washers, but our local true hardware store had shim stock. I bought a few inches in varying thicknesses.
When I pulled the caliper assembly apart I found there was enough wear such that the lower o-ring on the pivot arm had worked out of the recess a bit allowing the pivot arm to vibrate against the pivot pin. I had some gasket punches, but one was too small and the other too big. I sandwiched the shim stock between two 1x's with C-clamps and drilled a couple of 3/8" holes. Removed the shim stock and then used scissors to trim the outer circumference.
Put everything back together, no rattle or clacking. Took it for a ride today and even over the most challenging pavement and railroad tracks, not a sound. Seemed like I was riding a new bike. Oh, OK, a newer bike. :)
Re: Caliper Rattle
« Reply #28 on: August 08, 2007, 06:02:44 PM »
Well done Bob, I quess you can remove the earplugs again!
