Author Topic: What is this points part? Where does it go on the Dyna S ignitiion  (Read 1423 times)
Offline coolcat2002
PO put in a Dyna S.  I took it out to clean it and tried to put it back together (2 weeks later after taking everything apart.)
This part was in my "special" parts envelope that I labeled "points cover".
Everything fits but this thing is an "extra part".  Does anyone recognize it.  It's very thin and magnatized I think.  Coincidently it's the same radius as the Clutch bearing.
I've looked at the Dyna install guide. And it's not part of it I don't think.
I looked at the OEM parts and I don't see it either.
http://www.dynaonline.com/english/instruct/DS1-1_1-2.pdf
« Last Edit: July 06, 2007, 03:54:30 PM by coolcat2002 »
Offline Gordon
  • 750K1, 550K2
Re: What is this points part? Where does it go on the Dyna S ignitiion
« Reply #1 on: July 06, 2007, 03:50:35 PM »
If it's not part of the Dyna-s, and it didn't come off your bike, then where did it come from?  Doesn't look familiar to me.
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: July 06, 2007, 03:57:55 PM »
Looks like the washer that fits over your starter motor gear, under the alternator cover.
Offline neil young
  • striving to be an
« Reply #3 on: July 06, 2007, 05:35:09 PM »
i just recently installed a dyna s and that piece definately was not part of it
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline roadkill savior
    • Hondachopper
« Reply #4 on: July 06, 2007, 05:42:20 PM »
Exactly what that is! At least thats what I though when I first looked at it.
Offline coolcat2002
« Reply #5 on: July 06, 2007, 05:59:49 PM »
Ok, you guys are right!  It's the washer for the reduction gear by the stator.  I had to remove the left side "HONDA" like 10 bolts to get to it.
Thanks for pointing it out to me.
