After being beat up considerably on the 750F.... I aquired a 78 750 K head off of Ebay...
I expected to see the smaller valves. Indeed the valves are smaller. The intake inserts are also slightlhy smaller, again I can adapt to this.... So my intention is to use a 78 K head ontop of 78 F cylinders. Those two items mentioned are the only real difference I can see...
So now it's time to put it back together...... For those of you with far more experience than me on 750 engines.....
The third set of studs from the outside on each side have some recessed holes around the stud. I don't recall any rubber seals being there. There are 4 total..Clymers is about useless..
Does anything go in those recessed holes???
Shot at 2007-07-19
