Frank, if I weren't so lazy (and married) I'd do it again too.
The 10.00 motor #1 performance gain came from putting on a holley red fuel pump and regulator, 3/8" fuel line, and adding several additional vent holes to the cap. Once the motor's fuel starvation issues were solved, it ran pretty well so I turned up the boost.
#2 ET gain was the air shifter. I fought having one for a long time, this bike was supposed to be street bike, not a dragster... It was stupid to ever think I could shift like it can. Saves mucho wear and tear as well. Air it up and go.
I had burned up a new set of Arias 1000 pistons - that's how I figured out I had a fuel issue - and didn't have another big kit. But I did have several salvage yard stockers worth of parts.
SO...
I used what appeared to be the best of that stock stuff and plastigaged a bottom end together. Stock everything except an undercut tranny and HD clutch springs. Big cylinder studs. Stock pistons and pins. (The pins bent .005" after those passes
) Special ground down F-2 dowl & O ring for oil passage, and 5 base gaskets. Pistons sat in the hole about .125". Accutronix .043" copper head gasket. K head with good valve job and Manley SS exhaust valves. HD springs with aluminum retainers (that damn near broke in half)... F-2 broken band cam 108 lobe centers. Mallory sprint mag. ERC fuel.
Ran it all spring like this, rode it a around a little but the lack of torque on a 6.8:1 motor was bad. Drags were lots more fun, I ran from 1psi to 15psi boost just playing around, didn't beat it up at all. No high revs, easy low 11 second laps.
I never ran the 30 psi wastegate spring & jets until Q1 in Spokane that year, had NO idea it would run that much quicker with the extra boost!
