Thanks TwoTired and Eldar. TwoTired, that chart is great, and I have seen it around the SOHC board before. The reason I am working primarly on the main jets is because I figure with the stock needle positions, I should be able to get my mixture issues in the ballpark at WOT. Right now, with 130s installed and middle (stock) needle position, the bike boggs down and dies at WOT. (if I add choke then it will pull hard) For this reason, I think I need to increase jet size. Each time I increase jet size I also fiddle with my needle position to see how that effects things too, but I was just curious about others main jet size for my intake/exhaust configuration mentioned above.
Eldar, good point about the air bleed screws, I already have them a bit richer than the default setting, but its worth another shot.
I guess, I just need to wait a day or two until I get my 140s and try them along with different needle positions and see if that clears it up. Untili then, all I can do is speculate and frankly, there are too many "what ifs" to try and run through!
I'll keep you posted.
