Author Topic: cb550K seat vs. cb550F seat  (Read 3585 times)
Offline noelocol
    • DoTheTon
« on: July 13, 2007, 07:15:12 AM »
gents,
Would anyone know with certainty if these 2 seats are interchangable between the K & F model cb550s?
Would a K model seat fit on a F model and vice versa?
Thanks
___________
Noel
noelocol@rogers.com
www.DoTheTon.com
Offline Hope
  • How did I become an
  • SOHC member since '01
Re: cb550K seat vs. cb550F seat
« Reply #1 on: July 13, 2007, 09:09:54 AM »
The seat pans are different.  They will not interchange.  I've tried.  I have both the K (Cassandra) and the F (Jasper) sitting in my garage.  I cannot switch out the seats without modification....  Now, if you want to make some modifications, they will interchange...
or if you get a good K seat and want to put it on the F, you can take the padding/foam and leather/vinyl off and put it on the seat pan of the F, if you do not want to modify your bike.... and vice versa, if you get a good F seat and want to put it on the K, you can take the padding/foam and leather/vinyl off and put it on the seat pan of the F
Offline DrMark
« Reply #2 on: July 13, 2007, 09:10:55 AM »
My understanding of the 2 models is based on model year and gas tank design. The early models thru 1976 will not fit a 77-78 correctly. Also, the "F" tank is different from the "K" tank, so the fit on the front of the seat (against the tank) is different. Hope this helps?
1978 CB550K
1983 CB650SC Nighthawk
Offline noelocol
    • DoTheTon
« Reply #3 on: July 13, 2007, 09:37:17 AM »
Thanks guys.. definately been a great help!!..
I guess I should explain why Im asking...
Basically, I plan to put a 1975 cb750f tank on my 195 cb550f bike.
the cb750f tank is a bit longer by 2 inches.
I need a cb550 seat pan to build a matching cafe racer seat.
I know that the stock cb550f seat pan will need to be cut by 2 inches in the front to accomodate the bigger tank, which Im willing to do a donor seat pan, and not to my current seat.
I guess Im asking if the hinges and plunger lock would line up exactly the same on a K seat and an F seat.
Considering Im gonna cut 2 inches off the front of the seat pan, the lenght doesnt matter.
Thanks for all the comments!!
N
___________
Noel
noelocol@rogers.com
www.DoTheTon.com
Offline billstron
    • Billstron
« Reply #4 on: July 13, 2007, 10:12:22 AM »
My experience is that the hinges and lock are the same.  I just converted a 75F seat to a 78k.  The hardware lines up.  The thing to think about is if the back of the seat ends up in the correct position for you.  My 75 seat was just a little shorter than my 78, but the difference was all at the back of the seat.  My fender is not considerably more exposed as a result (probably 3in more).  I really like shorter look, but I'm not sure what you are going for.
Offline noelocol
    • DoTheTon
« Reply #5 on: July 13, 2007, 10:22:57 AM »
thanks so much...
So basically, If I dont care about theback or front of the seat, the hinges and plunger lock of a "K" seat will line up fine on a "F" frame...
THanks a million!!
Here is what I plan to do with the stock seat cb550 seat but chop the front 2 inches to accomdate a longer cb750f tank..
http://dotheton.com/index.php?topic=736.0
http://dotheton.com/index.php?topic=1032.0
Cheers
N
___________
Noel
noelocol@rogers.com
www.DoTheTon.com
Offline RAWNOG
  • Pretty pretty pretty pretty... Pretty good.
« Reply #6 on: May 26, 2011, 05:34:47 PM »
will a 1970 CB500 four seat fit onto a 1974 cb550?
1975 CB550k
