Author Topic: slow jets numbers  (Read 1080 times)
Offline ff154
slow jets numbers
« on: July 16, 2007, 08:24:11 AM »
1977 cb750k.  Does anybody know the part number for the slow jets (press in type).  Or where I can find out?  Thanks in advance.
« Last Edit: July 16, 2007, 08:38:06 AM by ff154 »
Offline mmtsquid
Re: slow jets numbers
« Reply #1 on: July 16, 2007, 10:05:26 AM »
Bump - I'm looking for the exact same info.
77 CB550K4
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: July 16, 2007, 10:11:05 AM »
google-    cmsnl
   They are in the Netherlands, but have a good online parts fische where you can find part #'s for all the CB's. Pretty sure those jets are no longer available though :P
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #3 on: July 16, 2007, 10:46:28 AM »
you might try e-mailing the folks at http://www.motorcyclecarbs.com.
They seem to have a wide selection of jets available, though the search only showed cb750 jets through 1976.
Dave
Offline ff154
« Reply #4 on: July 16, 2007, 11:28:01 AM »
I appreciate the responses.  I have browsed what seems like a million different web sites, but I haven't emailed anybody.  I was hoping somebody would know on here, because there is a small local shop that sometimes has stuff I need (if I can tell him the part number).  Thanks again for the help.  Hopefully I can find the part number somewhere.
luvhonda750
« Reply #5 on: July 16, 2007, 12:10:54 PM »
what is the matter with the old set? rebuild kits generally do not include replacements. I cleaned mine good along with rebuilding the entire set of carbs on the same year bike and I have a fine running machine, just need to make sure they are clean and you can get the next smallest electric guitar string through them okay, that is about a size 40 which is the stock jet size.
purveyor
« Reply #6 on: July 17, 2007, 08:39:44 AM »
hey,
i have a 78 750 f2 same press in slow jets
just finished cleaning and rebuilding.
i did not touch the slow jets just clean, clean ,clean then blow,blow,blow and you should be great
have fun I did...lol
