Author Topic: finding copression stroke  (Read 1117 times)
Offline pepsoy
« on: July 18, 2007, 12:22:50 PM »
hello. with the tappets totally slacked and the valve cover on, how do you find the compression stroke on the 1 or 4 cylinder (valves closed) when the tappets are slacked and  all valves are completely closed. or does it matter? do you start with the 1 cyl at the T mark just bc it's first and go from there for the adjustment. i guess it's 50/50 on getting it right!
Offline scondon
  • Mmmm......tasty bugs
Re: finding copression stroke
« Reply #1 on: July 18, 2007, 01:10:23 PM »
    Even with the tappet adjusters completely backed off, the rocker arm paddles will hit the cam lobe. You can pinch #1 intake rocker between your fingertips and feel it rise and fall as you spin the engine. Spin the engine until you feel #1 intake begin to rise, then look at your timing marks and spin the engine to 1-4 "T" mark. You are now on compression stroke for #1 cylinder and can set gaps for..
#1   intake and exhaust
#2  exhaust
#3  intake
 Spin engine 360 degrees(one revolutuion, returning to the 1-4 "T") and set gaps for..
#2  intake
#3 exhaust
#4 intake and exhaust
DISCLAIMER:  I may have the specs for #'s 2&3 cylinders reversed. Please consult your manual before proceeding as I am just going from memory. Process described is for a CB750
Offline jtb
  • An unlikely
« Reply #2 on: July 18, 2007, 01:13:39 PM »
Sean, I can actually wiggle both rocker arms on #1 when it is TDC on Compression stroke.
1977 CB750F
1985 V65 Sabre
Offline scondon
« Reply #3 on: July 18, 2007, 01:20:29 PM »
   When properly gapped,yes ;)
