3660 is not a very high altitude. 5-7K ft would be more of a concern.
If your air screw setting is stock, I would open it up some and see if that helps. As Bodi said, there are bits in the carbs that can fudge up and richen the mix.
If you are going to change jetting, and needle settings, you'll have to get inside them anyway.
Are you using resistor plugs? What numbers are they? Do they have an R in the number? Perhaps your spark is less than it should be?
