Author Topic: Painted carbs  (Read 1249 times)
Offline 6adan
Painted carbs
« on: July 30, 2007, 12:53:06 PM »
  Has anyone ever painted your carbs? Was there any problems? I was thinking of painting the main body of the carbs and polishing or plating the bowls and top caps.Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
Re: Painted carbs
« Reply #1 on: July 30, 2007, 01:10:13 PM »
I love to paint carbs...
http://www.sohc4.us/forums/index.php?topic=23258.msg250464#msg250464
Only problems is if you dump gas onto your paint ;D
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline kghost
Re: Painted carbs
« Reply #2 on: July 30, 2007, 02:13:58 PM »
I think if you just paint the bodies you'll be fine as far as gas goes.
After all gas should not flow upwards.
I would recommend that you prime them with epoxy primer and us a good polyurethane paint. By good I mean NOT out of a @#$% spray can.
Give it time to set up and it should be fuel resistant.
Stranger in a strange land
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: Painted carbs
« Reply #3 on: July 30, 2007, 02:28:50 PM »
What about anodizing them?  Anybody done that?
1977 CB750
okie
Re: Painted carbs
« Reply #4 on: July 30, 2007, 02:36:10 PM »
Sounds to me like a perfect application for powder coating.
Offline 736cc
Re: Painted carbs
« Reply #5 on: July 30, 2007, 06:04:39 PM »
My 70's cafe came w/ black carbs. Held up all these years, don't know what paint was used. Heres how they look.
Re: Painted carbs
« Reply #6 on: July 30, 2007, 07:24:31 PM »
Enamel paints are really fuel proof. I had a puddle of gas next to the starter cover for days, I just wiped it up. No issues with the paint.
