Author Topic: nice weekend i think i will stay in and paint  (Read 5017 times)
Offline kayaker43
Re: nice weekend i think i will stay in and paint
« Reply #25 on: July 25, 2007, 12:19:07 PM »
Spray Max comes in a few other flavors including 2 part primer,.. unfortunately, no colors.
You can get them all here:
http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=37014
Offline Peterbylt
« Reply #26 on: July 25, 2007, 11:13:31 PM »
I posted this one a while back but it fit this thread so I will post it again.
Just as an experiment I tried using a Minwax Spar Exterior polyurethane clear coat out of a spray can that I had purchased at Home Depot on my gas tank and side covers.
I know it is supposed to be used as a finish on wood but I tried it anyway.
I applied it over a base coat of blue metal flake Dupli-color Lacquer that I had applied a couple of months earlier.
Even with buffing and polishing the lacquer was quite dull and never looked very good.
The results were Quite spectacular and the finish came out very glossy and deep looking. As an added bonus its gas proof.
Currently the finish is 8 months old and I have had a couple of spots bubble in the clearcoat where I did not clean and prepare the lacquer underneath good enough. Truthfully I did next to nothing to prepare the lacquer except wash it. If I were to do it again I would clean it with mineral spirits to remove the old wax.
When I was spraying on the the polyurethane it would not go on evenly, it ran and puddled badly.
Frustrated I went up to the Home Depot to get some solvent to remove it. When I came back much to my surprise it had smoothed and leveled itself out and hardened nicely.
With the appropriate preparation I think this could work out very nicely.
Before Clear Coat
After Clear Coat
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
Offline neil young
  • striving to be an
« Reply #27 on: August 02, 2007, 02:55:06 AM »
alright the results are in....i went to a full serve gas station today.the gas jockey was an idiot.i unlocked the lid and started to take my helmit off when this twit starts to remove the cap.he dosnt realise there is a spot to set the cap into.when i start to reach for the cap he casually drops it onto the side of my tank  :'(fortunatly no chips or damage );Dthen when i tell him im going to do the filling he spills gas (not a lot but enough)on said tank.well the sraymax clear did what i had hoped for all along.after wiping the tank off the clear did not smear.checked it a few hours later,it looks good.$20.00 bucks a can is worth every penny
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
« Reply #28 on: August 02, 2007, 04:12:27 AM »
Nice work Neil, I like the yellow, but I'm not sure about the stripe though. (just my opinion, but) Every time I see your name I think about the old "After the Gold Rush" album, hell, you even look a little like your namesake did back in the seventies, ha ha! Cheers, Terry. ;D
