Author Topic: mounting bullets on headlight bucket  (Read 1665 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: August 01, 2007, 10:01:33 AM »
anybody have a how to on how they did this...mounting bullet signals on headlight bucket.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline MikeD718
Re: mounting bullets on headlight bucket
« Reply #1 on: August 01, 2007, 10:20:08 AM »
what do your signals look like? i have a set and it was pretty straight forward.
'76 CB750F
'76 CB550k
'66 CL160
  • stupid gloripope
« Reply #2 on: August 01, 2007, 12:18:18 PM »
these are it
RSV12K
« Reply #3 on: August 01, 2007, 01:05:10 PM »
Instead of using the bolts and nuts you already are using to hold the bucket on, run the light through the same hole and put a nut on the inside of the bucket. Make sure your ground wires are attached.
I used a pair of lights distributed Lockhart Phillips and they fit the existing nuts inside the bucket so it was a dead simple bolt on. Most of the bullet lights seem to come from the same place (don't know the brand) and I bet your's will be the same.
ronlarimer
« Reply #4 on: August 01, 2007, 01:28:00 PM »
A word of caution.
I did this on my last bike with dual headlights (SV650 with bates headlights no relation to a CB) and the bolts were long enough that when tightened they dented the reflector from the back.
There may be clearance and the dent didn't cause any issues, but I thought I would throw it out as something to check.
  • stupid gloripope
« Reply #5 on: August 01, 2007, 08:29:13 PM »
is it hard to run the wires for the signals into the headlight bucket.
RSV12K
« Reply #6 on: August 02, 2007, 03:59:53 AM »
Nope. Wires go into bucket through stems of signals. Connect to the existing wires (which on my 77 is one blue wire, one matching black with blue/white stripe; one orange wire, one matching black with orange/white stripe). I no longer recall which is right and left. You'll need to change the plugs on the end of each wire.
  • stupid gloripope
« Reply #7 on: August 02, 2007, 04:03:08 AM »
probably just splice and tape
RSV12K
« Reply #8 on: August 02, 2007, 06:09:38 AM »
You'll regret someday for not doing a proper job!
  • stupid gloripope
« Reply #9 on: August 02, 2007, 07:25:31 AM »
what do you mean change the plugs i have never changed blinkers.
jdigga
« Reply #10 on: August 02, 2007, 07:29:18 AM »
Those should plug into the existing harness without modification.
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #11 on: August 02, 2007, 07:48:12 AM »
Check out the finished product.  I've had bullets on my headlight bucket for a while.  Very east to install and wire and look good too.
http://www.sohc4.us/forums/index.php?topic=23258.0
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
