Author Topic: F Owners- What did we get ourselves into?  (Read 31361 times)
Re: F Owners- What did we get ourselves into?
« Reply #175 on: August 24, 2007, 03:44:58 pm »
See it depends on where you come from, over here in Oz with 24/7 riding weather, good original cosmetics like tanks, seats and sidecovers are almost impossible to find, and will set you back way more than the 500 buck sticker price.
I'd buy it just for those bits, even though I'm not really a fan of the fugly F/F1. If I bought it and imported it to Oz I'd paint and install the engine into my F2 frame, (along with the F2 carbs and pipe so no-one would be the wiser) and sell all the other bits for twice the sticker price! Cheers, Terry. ;D
Offline Wheelhorse77
  • She's got some Juice
« Reply #176 on: August 24, 2007, 06:13:48 pm »
I'd read the serial number off of your mill; Ha.
77 750F2 ressurected from the dead
ASE Advanced Level Master Tech
« Reply #177 on: August 24, 2007, 08:39:08 pm »
Don't worry about it Wheely, over here most folk wouldn't know what they were looking at anyway, and those that do would be happy to know that the more reliable F/F1 engine has been retro-fitted, as the F2 engine (deservedly) has such a bad rep. Cheers, Terry. ;D
« Reply #178 on: August 24, 2007, 09:24:26 pm »
I think that bad rep is all hear say. Besides, I contribute to the aid in fighting mosquitoes for the first five minutes.
« Reply #179 on: August 25, 2007, 02:37:22 am »
No it's not mate, I've got two stuffed F2 heads here, one appears to have dropped a valve and a guide, and the other one's valve guides are so loose in the head you can move them with your hand, I've never seen a K head like that, ever!
It's not just the valve guide material though, it's a combination of that, plus the actual valve angle was steepened in the F2/F3, the exhaust valves were too big and so it doesn't flow as well as a K head.
The cam design was poor which resulted in too much high speed stress on the cam chain, which caused the premature death of the cam chain, cam and rockers, rocker shafts etc, and the hardening on the valves themselves was suspect, causing "mushrooming" of the tops of valve stems.
All in all, a botched design. The best thing that can be done is to replace the head, barrels and pistons with "K" items, and then it's as "bullet proof" as a "K", or an F/F1.
Mosquitoes? The one's here are as big as Emu's! ;D
Offline jtb
  • An unlikely
« Reply #180 on: August 25, 2007, 05:28:14 am »
Unfortunately, Terry's right, Wheely.  (I really hate to admit that ;D ;D ::) ::))
1977 CB750F
1985 V65 Sabre
« Reply #181 on: August 25, 2007, 09:20:06 am »
Sounds like the trick flow heads when they first hit the market for mustangs. They ended up redesigning the angle to correct the accelerated guide wear.
I thought that the F head atleast flow'd better CFM wise, but I guess I was wrong.
Offline KB02
« Reply #182 on: August 25, 2007, 12:12:55 pm »
dont feel bad guys,at least ya`ll dont own k8`s. ;D
So what does that mean for me as I own an F1 and a K8?   :o   ;)  ;D ;D
I missed show and tell, too, but I'll try to post some pictures when I get home from work, but for now you can look at my Avatar pic.
QUESTION ON REARSETS -
I'll admit it, I'm a cheap b@sturd. I'd like to put on some rear sets without spending a ton (The whole Cafe project has been on the cheap). The left side is no problem to figure out, but what have all ya'll rear disked riders done for rear sets on these F's?
The way I figure it, the comfprtable position for me would be with the peg about an ich behind where the brake pedel spindle is.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #183 on: August 25, 2007, 04:55:56 pm »
Here you go mate, these are Suzuki GSXR600/750/1000 items that you can buy on EBay for around $100.00 per set. You'll only need to weld a couple of strap brackets to your frame like I did here, and then you'll have some very tasty rearsets indeed! Repeat the mantra, "Cheap is good, free is better", ha ha! Cheers, Terry. ;D
Offline UnCrash
  • Pass
    • My Blog
« Reply #184 on: August 25, 2007, 05:27:23 pm »
Nice tip Terry!
That looks right up my alley.
As a friend of mine in India once said "Cheap and Best"
« Reply #185 on: August 26, 2007, 08:16:59 pm »
What year bike should I look for to get donor K parts?
« Reply #186 on: August 26, 2007, 10:02:36 pm »
G'Day Wheely, well, the model evolved quite markedly during it's life, so the best engines were the last produced. My advice is to use either the F/F1 or K7/K8. They might have been the fugliest 750's, but they had (arguably) the best power-plants. Cheers, Terry. :D
« Reply #187 on: August 27, 2007, 06:23:30 am »
Thanks for the response!
I might have located a 78K, unsure of the mileage at this time.
On another note, the bigger vavles didn't do much in the F heads I take it huh? Maybe bigger, but lost velocity--lazy ports? Or is that an upgrade to the K head to use F valves? I would be unsure as to their installed height if there is a difference there because I do not have an actual shop manual to see if that could be achieved. I guess my point is that I ride maybe 2000 miles a year at the very best, so if the guides lasted 20G miles on average, that's ten years of riding for me. I'm just trying to weight the F vs K jugs and head swap.
I was also thinking it might be a good time to go 836 if I am going to be throwing K cyls on the thing.
Mreick? Comments?
« Reply #188 on: August 27, 2007, 09:23:49 am »
The bigger valves on the F head were to improve breathing at higher RPM and gain some HP.  The F models have a higher red line than the K models to take advantage of this.
I can see where head work to improve flow on a K head could make it as ,or more, effective than the F head flow.
Of course, if you had the same head work done to the F head...
I guess just about everything you do to an engine yo extract more HP, also shortens it lifespan.
« Reply #189 on: August 27, 2007, 06:21:31 pm »
.....I'm just trying to weight the F vs K jugs and head swap.
I have some (K4) 836cc cylinders and pistons that I'd like to swap with someone for some stock 736cc cylinders, K0-K6 engines.
« Reply #190 on: August 28, 2007, 06:05:18 am »
Sorry,
I'm all F'd up here
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #191 on: August 28, 2007, 09:47:13 am »
13 pages...  Has this become the "Shamless Post Boost Thread" for F owners?  Ah well, I'm just happy to see some pics of some F models I've never seen on here before.
1969 CB750K - Wrecked
1978 CB750K - Sold
1992 GS500 Streetfighter - Sold
1975 CB750F - Sold (sniff, sniff)
1994 VFR750F - Sold
1990 GSXR 750 - Sold
1999 CBR1100XX - Sold
2000 Triumph Legend TT - Bike of the week for me?
1992 Mustang - Paxton powered (12.02@115mph on street tires) and For Sal
« Reply #192 on: August 28, 2007, 02:17:41 pm »
Ooh ooh, pick me, pick me! I've got some Mark, and I'll pay the shipping for yours too! Cheers, Terry. ;D
« Reply #193 on: August 31, 2007, 01:19:22 pm »
OK guys, I'm not sure of the final quality but check this website out.
http://lpmreplicaparts.com/
« Reply #194 on: August 31, 2007, 05:37:21 pm »
Hey thanks Jerry, and welcome back from that incredible ride! Next year I wanna come, but we probably won't get much further than the first bar we hit, ha ha!
 I just contacted these guys to get a total price on an airbox and sidecovers for my K0, the weather is warming up here, so I can shoot some paint on them in time for some summer riding! Cheers, Terry.
« Reply #195 on: August 31, 2007, 07:52:10 pm »
I need to start an individual thread and we all vote on which dealer/vendor we want to go with. It may be the one willing to cut us the best deal.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #196 on: August 31, 2007, 07:56:11 pm »
Those are the same guys I linked on ebay I believe.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline pddpimp
« Reply #197 on: September 01, 2007, 05:40:44 am »
I bought a set from them this last winter. The quality for my K7 was great. They fit very nicely and they have a bit more flex than the OEM ones. And they are cheaper than nice originals on Eb@y. I will buy from them again when I need to get another set. A+ stuff.
When the majority of the United States population get to be 70 years old, they will finally realize what is really important. And by then it'll be too late.
-'77 CB750 Cafe/Muscle bike (early clone)
Soon to have a hopped up 836cc *sold*
-'75 CB750 with a little bit of character
« Reply #198 on: September 01, 2007, 05:24:25 pm »
Thanks for that info mate, I'm gonna order some stuff from them shortly. Cheers, Terry.
« Reply #199 on: September 04, 2007, 10:46:12 am »
