Author Topic: will lower the rear shorter springs hurt handling  (Read 1454 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: August 02, 2007, 04:05:13 AM »
Was thinking of lowering it but dont want to give up handling.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline Gordon
  • 750K1, 550K2
Re: will lower the rear shorter springs hurt handling
« Reply #1 on: August 02, 2007, 04:19:28 AM »
It will affect the handling, the amount depends on how much you lower it.  Whether or not it "hurts" the handling is up to you to decide.  Lowering the rear in relation to the front, in effect, slows down the steering.  High-speed handling is a little easier, slow-speed handling is a little more sluggish, but like I said, the amount depends on the difference.  I have rear shocks that are about 1 and 1/2" inches shorter than stock, and pushed the front forks up in the triple trees the same amount to off-set the difference.
Offline UnCrash
  • Pass
    • My Blog
« Reply #2 on: August 02, 2007, 04:56:39 AM »
Does this leave the overall handling like it was at stock, or is there some difference because the center of gravity is 1 1/2" lower to the ground?  Is that difference better (in a non-aesthetic way) from your perspective?
Offline xtalon
« Reply #3 on: August 02, 2007, 06:15:52 AM »
You can help offset lowering the rear by also lowering the front (i.e. pulling the front forks up through the triple clamp).  This will quicken the steering back up; however, lowering a bike also reduces cornering clearance (i.e. things will drag the ground sooner).
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: August 02, 2007, 07:19:17 AM »
It's better, from my perspective, because I can put my feet flat on the ground now.  Handling is essentially the same, but like Xtalon said, the cornering clearance is slightly reduced, but in my experience, not enough to make a difference.  I can carve some pretty tight corners up in the mountains at high speeds and very rarely scrape the pegs.
  • stupid gloripope
« Reply #5 on: August 02, 2007, 11:12:02 AM »
CAN YOU JUST ADJUST THE SHOCKS TO LOWER THEM ON A 1980 CB650....ALSO HOW ARE YOU GUYS LOWERING THE FRONT END.
rstarcher
« Reply #6 on: August 02, 2007, 12:39:32 PM »
I put 11" shorty shocks on the back of my 750k1 (2 inches shorter than stock) and did nothing to the front.  I'd say it's easier to take corners at 20 mph+ and much easier to walk the bike since my feet now fully touch the ground.
Randy
  • stupid gloripope
« Reply #7 on: August 03, 2007, 03:14:08 AM »
is there a brand or where can you get shorty shocks from are they oem or aftermarket.
Offline Roach Carver
« Reply #8 on: August 03, 2007, 06:20:32 AM »
these guys have some at the bottom of the page. http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
tas motorsports also has some (I think) and they are great guys to deal with.
