Just wondering if it's possible to use dohc 750 pistons in a sohc 750? i've got access to some big bore kits (72mm, 1010cc's in a dohc...), but i don't know if i can use them pistons in a sohc? i know that the stroke is different (the sohc is longer by 1 mm) - are there any other differences? anything i'd need to do, aside from bore/resleeve the cylinders (and weld 'em...)?
i'm thinking there's an issue b/c of the 4-valves versus the 2-valves, so the top of the pistons may not work b/c of the cuts for the valves?
thanx for any info!
