Just curious what size jets and clip position other people are running with the "605" 591cc big bore kits. This is with stock 500/550 carbs.
My bike has the "605" pistons, ported cyl head, Web 58A cam/springs, 4-1 Mac megaphone exhaust, Uni pod filters, DynaS, 3ohm coils, D7ES plugs.
I started off running 40 pilot, 120 main, and clip on the 4th notch (one richer than stock). Started great, part throttle was good- but it had a huge bog around 3/4 throttle. WOT was fine once it got past the bog, plugs read fine. I noticed the bog is worse with the choke on 1/4 and clears up as soon as I open the choke back up. I'm thinking its too rich in this area, so maybe raising the clip back up to the 3rd notch will help....
Looking for input, thanks!
