I think I'm going to have to revise my previous statement. I've never owned an F model and it seems that the F model has a longer swingarm than the K models. GroovieGhoulie posted the below in the topic "Lets talk extended swingarms for a minute..."
The F model swingarm is right about 1" longer than the K swingarm. This was done when the factory modifed the frame for the Super Sport models. They initally shortened the rake by one degree, which in turn shortened the trail. They did this to make the steering quicker, more lively, more "Super Sport-ish", whatever. In order to restore some straight-line stability to the bike, they extended the swingarm by 1" in order to lengthen the wheelbase.
Inital test rides were not too good with most testers saying the bike's handling was "diabolical", "unpredictable" "scary" or "just plain dangerous". At the tester's advice, Honda went the other way and cranked in more rake and trail: one degree more rake than the K models (28 degrees 10 minutes, versus 27 degrees, 10 minutes), this also lengthened the trail from 3.7" on the K to 4.5" on the F, which brought it more in line with period British bikes (regarding trail).
Despite the fact that the longer swingarm was sort of a "band-aid" to restore straight-line stability in the steeper-rake/shorter trail designs, it was kept for the production F models with the longer rake and trail.
The '77 and '78 K models used the F frame (with it's longer rake and trail and longer swingarm), however, they still had the drum rear brake. They did however, have the 630 chain, unlike the earlier 530 chain. The wider swingarm, originally designed for the wider disc brake system, could accomodate the wider sprocket and the drum brake hardware and axle was reportedly unique to the K7 and K8 models (wider).
The F model swingarms are a little wider to accomodate the rear disc brake and associated hardware, and supposedly it is not a drop-in mod to a K model bike using the stock rear wheel and drum brake (which also means that the F rear wheel and disc set-up is not a drop-in mod with a K swingarm either). However, reportedly, you could swap the entire F swingarm, wheel, disc, caliper and brake system and brake system mounting hardware onto a K bike.
Hope this rambling discourse helps somewhat
