Author Topic: bondo tonight  (Read 1790 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
bondo tonight
« on: August 10, 2007, 11:16:22 AM »
Got tired of waiting for a different tank without dents so I am going after my tank with bondo tonight. Any advice or experience would be awesome.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline WJL75
Re: bondo tonight
« Reply #1 on: August 10, 2007, 11:48:16 AM »
Use as little as possible, and smooth out what you can before it sets.  Once it dries, use 60, then 150, 400, 600 (wet) grit sandpaper to smooth it out gradually.
wjl75
1976 CB550K Cafe
Offline neil young
  • striving to be an
Re: bondo tonight
« Reply #2 on: August 10, 2007, 11:52:02 AM »
once you add the hardener it sets really quickly.mix small batches
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline matchanu
Re: bondo tonight
« Reply #3 on: August 10, 2007, 11:55:08 AM »
Do NOT use wet sandpaper on bondo.
Bondo absorbs water and will swell and crack. Only wet sand after you spray primer.
Offline WJL75
Re: bondo tonight
« Reply #4 on: August 10, 2007, 12:01:47 PM »
Opps...you are correct.   Scratch that part about wet sanding.
wjl75
1976 CB550K Cafe
Offline matchanu
Re: bondo tonight
« Reply #5 on: August 10, 2007, 12:12:30 PM »
One more thing. If possible, use duraglass on your first layer. It's a whole lot stronger than bondo and more flexible. It doen't finish as well, but then a very light layer of bondo ofver the duraglass works great.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: bondo tonight
« Reply #6 on: August 10, 2007, 12:19:16 PM »
Bondo SUCKS !
I leave bodywork to people who know what they are doing, when it comes to that I do not..
  • stupid gloripope
Re: bondo tonight
« Reply #7 on: August 10, 2007, 12:23:21 PM »
this is going to be trial and error. It is a fairly decent size dent...should i do a bunch of layers to get it filled or should i wait till sand untill i am close to where it needs to be or do you have to sand every layer....also if it cracks can I just rebondo it.
Offline stearmandriver
Re: bondo tonight
« Reply #8 on: August 10, 2007, 03:13:43 PM »
I have used the stuff over welded seems in cars and motorcycle tanks.  Use as little as possible as previously mentioned.  When sanding smooth, it helps to detect high and low spots if you wear a pair of thin nitrile or latex gloves.  The added layer between your skin and the surface helps you feel the imperfections better.  Don't ask me why.  It just works well for me.
Good luck
Dave
"Everyone needs to be passionate about something, anything...  I'll help you collect acorns if thats your thing, just don't sit there and tell me your bored!"
  • stupid gloripope
Re: bondo tonight
« Reply #9 on: August 10, 2007, 04:18:14 PM »
people that know what they are doing want more than i payed for the whole bike
Offline Swede
Re: bondo tonight
« Reply #10 on: August 10, 2007, 04:49:28 PM »
When I did my tank (first bondo experience) I thought it looked pretty good until I sprayed with primer then I could see all that I had missed including low and high spots.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
Re: bondo tonight
« Reply #11 on: August 10, 2007, 04:59:32 PM »
I hate to say it, but welcome to owning an old bike ;)
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Re: bondo tonight
« Reply #12 on: August 10, 2007, 05:13:31 PM »
Use a good wet sanding block as well.  Your fingers and bare hand will leave and uneven surface in the primer.
Offline BlindJoe
Re: bondo tonight
« Reply #13 on: August 10, 2007, 06:02:06 PM »
I'd recommended going to a body supply store and ask them for their best body filler, it may be more expensive but it will save you a lot of frustration. I spent hours "bondoing" a tank one time and thought it looked pretty good, but when I put the primer on it looked terrible. If your dents are small you could probably get away with using bondo, but if they're the size of a quarter or bigger get the good stuff.
Offline sparty
  • I just play one on TV
    • Gallery
Re: bondo tonight
« Reply #14 on: August 10, 2007, 07:40:09 PM »
I love the smell of bondo.  It brings back some good and bad memories from my first car. ;D
Sparty
1972 CB750 K2 Cafe' Style
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: bondo tonight
« Reply #15 on: August 10, 2007, 11:48:50 PM »
A little dent in a gas tank sounds good about now!!!!!!!!  Day 17 filling and sanding............
http://www.sohc4.us/forums/index.php?topic=24474.0
Offline neil young
  • striving to be an
Re: bondo tonight
« Reply #16 on: August 11, 2007, 12:13:06 AM »
lol ....no #$%* seaweb
1972 CB500 k1
1974 CB550
1977 cb 550
Offline matchanu
Re: bondo tonight
« Reply #17 on: August 13, 2007, 09:27:44 AM »
Did you try and pull the dent a bit first?
That crappy little "painless dent remover" you see on the infomercials actually works really good.
Basically glue a rod onto the dent, place on a slide hammer and pull it out.
It's easier to pull out a dent and grind it down (not too much metal) to smooth rather than fill a crater with filler.
