What goes with cussing?
Toast and Jam. Though not necessarily in that order...
I did a LOT of that getting those carbs back on. I thought I was going to have to pull the engine, or at least drop the front motor mounts...
Took me 2 hours to get the airbox and carbs back on, I'm still not over that.
Yes, improper install procedure can be frustrating. If you do this again, here's the easiest way I know:
Remove the band clamps **completely** from the rear rubber couplers.
Remove the two bolts that anchor the filter box. (This allows the couplers to move back the quarter inch you be happy to have.)
Install the front rubber couplers first.
Spray silicone or soap spray onto the rear rubber couplers. And, similarly lube the inside and "faces" of the front rubber couplers.
March the carbs across the bike from left to right, using a dull tipped probe to push the rear couplers out of the way.
You will have less wrestling to seat the carbs into the front couplers if they aren't 30 years old and set in their ways.
(The next time I do this, I'm going to try laying a flat sheet of metal (like a steel rule) across the rear couplers to act as a ramp that helps deflect the rubber bits. I can see it helping in my mind. But, I haven't tried this yet. I imagine the age hardness of the rear couplers may impact the plan, as they may retreat into the plenum box instead of the collapsing in compliance.
