Author Topic: White wire from alternator to regulator  (Read 715 times)
knack
« on: August 13, 2007, 12:36:11 PM »
I am changing out my separate rectifier and regulator for a one-piece unit from a donor bike. The white wire to the original regulator (I believe it's called a "field coil supply") has no matching wire from the new unit. Can I just isolate the white wire and tape it back? Thanks much.
Re: White wire from alternator to regulator
« Reply #1 on: August 13, 2007, 12:56:43 PM »
No.  The field coil makes an electro-magnetic field in the alternator, without which, the alternator will make no output.  The white wire powers the field coil.  Some regulators are designed for bikes that have permanent magnets in the alternator and therefore supply no power for it.
I'd guess your donor bike (whatever that is) used a permanent magnet in the alternator and it's regulator won't function as you hoped in an SOHC4.
