Author Topic: Carbon deposit on pistons... is this normal?  (Read 2525 times)
Offline billdramp
  • DOOMTOWN RIDERS / PORTLAND, OR.
« on: August 14, 2007, 03:52:46 PM »
Hey folks,
I'm in the middle of my first engine build  on my 400four and when I took the head off... the pistons have what appears to be alot of carbon build up on the top of them... Is this normal?
Should I replace the piston because of this? ???
Any thoughts are appreciated.
Billy / PORTLAND
1975 CB750K (daily rider), 1974 CB550K (sold), 1974 CL350 (sold), 1973 CL350 (when I get around to it...), 1971 CB750 (in boxes), 1978 CB750F in boxes, 1976 CB750F SUPERSPORT (sold), 1975 CB400 FOUR (crashed), 1976 400 FOUR (work in progress), 1977 cb400f
SOHC4  MEMBER #1527
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Carbon deposit on pistons... is this normal?
« Reply #1 on: August 14, 2007, 03:54:48 PM »
Lots of carbon should be removed.  It can cause hot spots as well as raise the compression.  No need to replace pistons unless there is evidence that the pistons/cylinders are worn.  Use the end of a hack-saw blade to scrape off the carbon with the piston at Top-Dead-Center (TDC).
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: August 14, 2007, 05:50:26 PM »
the pistons are already removed. you want more CR, right billy?  ;) ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: August 14, 2007, 06:55:48 PM »
Clean the piston tops and clean the combustion chambers.  You'll be amazed at how much easier your bike starts when you're finished and how much better it idles.
Offline 75750SS
  • 75 750F, 2010 Concours ABS
« Reply #4 on: August 15, 2007, 12:25:36 PM »
Do it!  I noticed an improvement (idle and throttle).  Scrape what you can off the heads and pistons.  You can use ATF to soften the crud.  Permatex gasket remover works too.  I sprayed into the intake and exhaust ports.  It turns into a black slime, just blow out with carb cleaner.  To help clean out the exhaust ports, I bought a couple of copper brushes, the kind used to clean a gun bore (32 caliber and 12 gauge), which can attached to a drill. Used compressed air to blow out the dust.
Offline vintage_racer
« Reply #5 on: August 15, 2007, 12:42:34 PM »
If jetting and ignition are right, a heavy buildup of carbon indicates a problem of some sort such as low compression. Inspect the bores and rings before putting the motor back together.
Dan
Ride that old SOHC hard
« Reply #6 on: August 15, 2007, 03:14:49 PM »
You can boil off most carbon in boiling water. Scub what is left over using one of the above methods.
Offline edbikerii
    • Gallery
« Reply #7 on: August 15, 2007, 03:28:12 PM »
I've found kerosene to work pretty well at dissolving carbon deposits too.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline aptech77
« Reply #8 on: August 15, 2007, 07:20:01 PM »
Run some Seafoam to keep it under control.....
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #9 on: August 15, 2007, 08:32:07 PM »
Hey folks,
Billy / PORTLAND
You bet! It is normal for a 30 year old bike to have carbon on the pistons.  After 30 years piston rings would be worn just from heat cycling alone.  You may have oil blow-by which caused the carbon build up.  It could also be too rich of a mixture.  If your bike is a "short tripper" carbon buildup will occur more easily.  Your bike most likely ran leaded fuel in the old days, so that could also cause the build up.  Today's gas is much cleaner to burn.
Clean the pistons, inspect for damage, install new rings, etc.
Sparty
1972 CB750 K2 Cafe' Style
