Author Topic: CX500C problems  (Read 7844 times)
Offline mmtsquid
CX500C problems
« on: August 15, 2007, 12:11:20 PM »
Just picked up a CX500C for my brother in law - after replacing the CDI unit, it started right up.
but, it backfires like crazy and has NO POWER.
I pulled the carbs, and they were pretty clean, jets clear, etc.
Plugs are very sooty.
Any ideas?
77 CB550K4
Offline KB02
Re: CX500C problems
« Reply #1 on: August 15, 2007, 01:07:16 PM »
Timing and Air filter come to mind.
Pull the air filter out and start it up. See if it runs better or worse.
Not sure if timing is adjustable on those. If it's CDI, probably not. But it does sound like an option if it is.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: CX500C problems
« Reply #2 on: August 15, 2007, 03:11:13 PM »
What plugs are you running?
No.
Offline 333
  • Time for change
Re: CX500C problems
« Reply #3 on: August 15, 2007, 05:29:22 PM »
You might want to double check the CDI wireing, including the pulsers.  The symptoms you describe might be caused by the pulsers being reversed.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline turtle
  • 1980 CX500 Custom
Re: CX500C problems
« Reply #4 on: August 15, 2007, 06:00:48 PM »
I've got one too. I'm not sure about your problems but you may like to post in the "Ask the Gurus" section on here:
http://australiancx.asn.au/forum/index.php.
1972 CB350 Four
1977 CB750 K7
1979 Suzuki GT250 X7
1980 CX500 Custom
1980 CX500 Shadow
1981 CB900 Bol D'or
1982 CB750 F2
"If it ain't broke, don't fix it."
Offline mmtsquid
Re: CX500C problems
« Reply #5 on: August 16, 2007, 06:26:16 AM »
I pulled the air filter, and it ran worse.
I will try the other ideas this weekend - it has to be something simple!
77 CB550K4
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: CX500C problems
« Reply #6 on: August 16, 2007, 12:09:57 PM »
No.
Offline mmtsquid
Re: CX500C problems
« Reply #7 on: August 16, 2007, 01:27:58 PM »
Oh - the plugs are champion ra8hc.
I'm not sure if they are equivalent to D8EA or not..........
77 CB550K4
Offline 333
  • Time for change
Re: CX500C problems
« Reply #8 on: August 16, 2007, 05:36:07 PM »
Get the NGKs.  The only bike that Champions work well in are old Triumphs.
Online bryanj
Re: CX500C problems
« Reply #9 on: August 17, 2007, 04:17:26 AM »
Put a NEW air filter in it, The CX was the only honda i ever came accross that needed regular replacement, also get fresh gas into the carbs as even a few days old goes off enough to give a bad start and the carbs are real pernikety on being clean
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: CX500C problems
« Reply #10 on: August 17, 2007, 11:19:15 AM »
The reason I asked is because, I think, the ra8hc is a resistor plug. You do NOT want a resistor plug.
A resistor plug will cause the issues you are having.
Replace with D8EA and see if your problem clears up.
The ra8hc is equivalent too the D7EV plug, which was replaced with the 5686 which is a resistor plug.
Again, resistor plugs will cause the kind of behavior you are describing, as there is too much resistance for a good spark.
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: CX500C problems
« Reply #11 on: August 17, 2007, 11:24:33 AM »
After more research, yes, the plugs you are running ar resistor spark plugs. Wrong kind.
http://www.championsparkplugs.com/more_info.asp?AAIA=&pid=4422
No.
Offline mmtsquid
Re: CX500C problems
« Reply #12 on: August 17, 2007, 11:48:19 AM »
God bless you all - I'll give it a shot tonight and let you know!
77 CB550K4
Offline LoopsAndLogic
  • Dang IT!!!
Re: CX500C problems
« Reply #13 on: August 20, 2007, 09:05:41 AM »
Sorry to hijack your thread, but is running NGK-R plugs in the SOHC-4's not recommend too, or is this just not recommended for CDI  equipped bikes??
Thanks
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: CX500C problems
« Reply #14 on: August 20, 2007, 09:25:01 AM »
Thanks
LL
SOHC4's do not run resistor plugs.
No.
Re: CX500C problems
« Reply #15 on: August 21, 2007, 03:15:43 PM »
Thanks
LL
SOHC4s came with resistors on the plug caps instead of the spark plugs.  If you want to run resistor plugs replace the plug caps with zero resistor types.  The spark voltage capability of the stock SOHC4 is rather low by today's standards.  Adding extra resistance to the ignition path requires more voltage development in the coil to overcome the spark spark gap.  When the plugs are new, this is seldom an issue.  But, plugs require more voltage to fire as they age, and approach the upper limit on the coil capability.  Adding inline resistance exacerbates the issue and sooner spark plug replacement.
Note that some resistance is a good thing as it broadens the spark duration at the gap and reduces coil heating.  But, it is analogous to air in your tires, too much-bad, too little-bad, just right- good.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: CX500C problems
« Reply #16 on: August 21, 2007, 03:26:12 PM »
So... how'd it go?
No.
  • Dang IT!!!
Re: CX500C problems
« Reply #17 on: August 23, 2007, 03:13:52 PM »
Get rid of the NGK-R's. Got it!! ;D
 I hope it all works out for you with your CX. I use to own one. Great bike!!
LL
My rides:
Past Rides:
Offline mmtsquid
Re: CX500C problems
« Reply #18 on: August 27, 2007, 05:09:27 AM »
Well, it made a LITTLE bit of difference.........
Now, left cylinder runs great, right cylinder cuts in occasionally - but when its running, it REALLY pulls!
I was out of town for a week, so I'll play more this coming weekend......
77 CB550K4
upperlake04
Re: CX500C problems
« Reply #19 on: August 28, 2007, 09:54:06 PM »
  Some SOHCs, for sure the 1978 750F3s for the Canadian market, apparently do use resistor plugs. Here's a  link to the NGK website which explains the symbol code stamped on the plugs and page 43 from the 78F Owners Manual.
http://www.ngksparkplugs.com/techinfo/spark_plugs/partnumberkey.pdf
Re: CX500C problems
« Reply #20 on: August 29, 2007, 06:23:39 PM »
So the question is...
Do the Canadian F3s have resistor plug caps?
upperlake04
Re: CX500C problems
« Reply #21 on: August 29, 2007, 08:24:07 PM »
 I don't know.  Maybe you can tell me. #1 cap is marked Nichiwa VDO5F, as are the rest, and if I am using the meter correctly has 6.7ohms resistance.
Re: CX500C problems
« Reply #22 on: August 29, 2007, 11:29:59 PM »
Was your F3 first sold in Canada?
Your measurements indicate a resistor plug cap.  But, the 750 values are usually 5K +/- 10%.
I wonder if the Canadian government had a stipulation for distribution into Canada?  Is there, was there, a spark plug Mfg in Canada during the 70s?  Was RFI a political football for that era?
I don't know of a technical reason why Canada would need extra resistance in the HT leads (Besides RFI).  You'll have to change plugs sooner, unless you have a high energy spark system.
upperlake04
Re: CX500C problems
« Reply #23 on: August 30, 2007, 10:54:21 AM »
TT - this F3s history is unknown to me. Starting in 1977, all new vehicles sold here were required to have the metric speedometer scale dominant. That would be a clue, but this one had mismatched replacement gauges when I bought it.
  The caps measure 5.3, 6.1, 4.4 and 4.8 ohms on the 200K scale.
  A quick look at a business guide shows NGK to have a factory in Canada now which does not export but as for the RFI situation in the 70's, I have no idea. A reasonable theory though.
  From what you've written, it appears a switch to non-resistor plugs at the next change might be slightly beneficial.
« Last Edit: September 04, 2007, 08:53:05 AM by upperlake04 »
Offline mmtsquid
Re: CX500C problems
« Reply #24 on: September 04, 2007, 05:31:02 AM »
OK< now I'm stumped - The bike woll only run on one cylinder!
The right fires right up, but left only fires occasionally - both sides are getting good spark, carbs are very clean.
What else could it be??????
77 CB550K4
