Author Topic: Anyone Used/Using Valvoline Motorcycle Oil?  (Read 6780 times)
Justin
« on: July 09, 2005, 08:51:36 PM »
If so, what viscosity grade?
How did it work for you?
Would you recommend it or something else?
Re: Anyone Used/Using Valvoline Motorcycle Oil?
« Reply #1 on: July 09, 2005, 09:07:06 PM »
Justin,
A mate of mine used it in the Sixties/Seventies in a drag bike. I think it was a multigrade racing oil.
As far as I know he had no problems with it, and the bike was the fastest unsupercharged bike outside the USA.
Regards Sam Green.
« Reply #3 on: July 09, 2005, 09:31:00 PM »
Justin,
The guys in the States will be able to tell you, but I would assume it is ok.
Most Motorcycle oils differ from motor oils in that anti friction addatives in motor may cause clutch slip in a bike.
Offline heffay
« Reply #4 on: July 09, 2005, 09:40:37 PM »
i use valvoline in the truck and belray in the bike.  actually, i use whatever is not generic in the truck and belray in the bike.
74 jeep j20
73 cb350f
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #5 on: July 09, 2005, 10:41:49 PM »
On my 73 cb350 twin my dad always used castrol 10w40. I,m  not sure if it was just normal auto oil or motorcycle oil.  It worked fine now on my last oil change i couldnt find any castrol motorcyle oil. So I used valoine motorcyle  oil 10w40.  Sometimes theres false neutrals very rare it was with both oils.  But  it seemed every once in a while  it will miss a gear. It may be cuz i,m not giveing it a full click. But with castrol it didnt happen as much  all in all though the oil (valoine) seems to hold up well though.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline heffay
« Reply #6 on: July 10, 2005, 11:59:07 AM »
one last thing... you can mix your brands but don't mix your viscosity
kinda like you can pick your friends
and you can pick your nose
but you can't pick your friends nose
Justin
« Reply #7 on: July 10, 2005, 12:01:04 PM »
Why?
derekd
« Reply #8 on: July 10, 2005, 12:25:29 PM »
 Ive been running there 10/40 for 1000 miles this season with out any problems.Not thet i would believe there should have been any in that kind of mileage.I thought it was worth trying its locally availible.Guess i wont really know for a couple years huh?
        Derek
        cb350four
Offline Chris Liston
« Reply #9 on: July 10, 2005, 05:46:10 PM »
I've been using standard auto 10w40 in the bike since I got it.  I switch to Honda 10w40 last year and it made my shifter much more clunkier than with that auto oil.  I'm going back to auto oil on my next change.
1976 CB550F Cafe in progress
Offline Uncle Ernie
« Reply #10 on: July 10, 2005, 07:45:49 PM »
I use Valvoline Racing Oil. I used to use Castrol, but I think it produces more "ash". I have no idea what I'm doing though, either. Maybe ash is a good thing (?). This is the kind of thing the Bemer guys relly sink their teeth into  :D.   I suspect that any good oil is OK to use. I've heard pros and cons on regular vs synthetic vs car type vs motorcycle specific oils.  I know they're different kinds of engines, but EVERONE who knows anything about Indians says to use Valvoline Racing Oil.
For some reason, mixing viscosities yourself is not the same as buying it. 10-30, for example, is basically 10 weight oil with additives that makes it thicken up when it gets hot, but it's not actually 30 weight oil.  Single viscosity oil is more "pure", if you will, and will withstand heat and shear better. For some reason, mixing viscosities yourself gunks up the engine. I work with some mechanics who often cluck their tongues when they look under some valve covers because of that.
There has been a fairly regular brouhaha about putting car oil in motorcycles because the theory is that car oils today are too slick and will cause clutch slippage in MCs.  Well, if you've been using car oil and it works- keep using it. If your clutch slips, try MC specific oil.  My 2 cents.
Justin
« Reply #11 on: July 10, 2005, 08:22:36 PM »
Why do they recommend Valvoline Racing Oil? Which one (VR1, Synthetic, Conventional)?
Mixing viscosities doesn't "gunk" up your engine. Additive clash has been discussed in the past and almost totally ruled out now (with the exception of extreme mixes). You'll simply achieve a blend with a new viscosity.
I take it you are referring to sulfated ash? Don't worry about it! Lab tests in a controlled environment may be able to detect noticeably higher levels of valve and combustion chamber deposits with usage of an oil with higher additive levels, but its effects in service are negligible
SAE single-grade oils are the hot ticket for extreme racing usage, but I don't see the need otherwise. Pumpability and overall flow at startup (regardless of how hot it is!) are highly reduced given these oils relatively high viscous nature, in turn causing high rates of overall wear. Multi-grade oils for street usage are much more ideal.
Automotive oils in recent years have done two things that make their usage in motorcycles a less than ideal proposition:
1. Additive packages, mostly the usage of ZDDP, has been highly reduced to aid in emissions and exhaust system component life. While this is ok for modern cars, high valvetrain loading and shear rates present in wet-clutch motorcycle engines demand an oil that can properly cope with such operating conditions. Heck, even Japanese automotive manufacturers are complaining about the lack of appropriate protection regarding timing chains!
2. GF-4 oils have been furthered modified from previous generations to ensure even higher levels of fuel efficiency. The commonly described "friction modifiers" can play havoc with a wet clutch setup.
MPH2
« Reply #12 on: July 10, 2005, 11:01:03 PM »
lol i thought you were asking a question or answering it ;D
Justin
« Reply #13 on: July 10, 2005, 11:16:16 PM »
I'm just looking to see if anyone here has ran the Valvoline stuff in their SOHC4...I might know one or two things about engine oils in general, but I don't know much yet regarding what these bikes like/don't like.
Offline Trevor from Warragul
« Reply #14 on: July 10, 2005, 11:52:33 PM »
I use Valvoline XLD in all my bikes (that's the brand name here in Australia).  It's cheap enough to guarantee that I replace it in every bike once a year.  The mechanic who most recently did the shims on my CBX 1000 was in awe of the condition of the cams - he said they looked virtually brand new - this on a bike that's done around 120,000 kilometres.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline MikeDeB
« Reply #15 on: July 11, 2005, 02:05:52 AM »
Honda GN4 10w40 in both single cammers and Castrol Syntec 20w50 in both Ducs.  Valvoline for the car.   ;D
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline Uncle Ernie
« Reply #16 on: July 11, 2005, 03:53:48 AM »
Why Valvoline Racing? No idea. Sometimes something starts out as a grain of sand and ends up a beach. However, this is for a flat head side-valve engine. I have a feeling that chunks of dead dinosaur would do just as well  ::) The other stuff are things various mechanics have told me from their observations.  Some people I respect seem picky about their oil, and some just tell me to make sure it's topped off with whatever (barring racing, as you said).  Some people think synthetics are too thin for some applications. I've gone nuts listening to too many people.
Offline gkw120649
« Reply #17 on: July 11, 2005, 08:20:12 AM »
I've been using for two years and it seems to work fine.  10W40 last year.  20W50 this year.
Greg in Chicago.
1977 CB-750 K
1978 CB-750 K
Justin
« Reply #18 on: July 11, 2005, 09:12:09 AM »
Greg in Chicago.
Did you notice any difference between the two viscosity grades?
Offline gkw120649
« Reply #19 on: July 11, 2005, 10:13:36 AM »
I'm changing the oil tonight and I'll send you a reply after I take it for a spin.
Greg in Chicago.
1977 CB-750 K
1978 CB-750 K
markpeddle
« Reply #20 on: July 12, 2005, 08:31:15 AM »
Tell me once again what will happen if I have 10-40 in the bike and drop some 10-30 in for a quick fix. I'm afraid of the answer.....gulp!
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #21 on: July 12, 2005, 08:36:21 AM »
Any oil is better than not enough oil.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #22 on: July 12, 2005, 08:36:54 AM »
Short term get you home and do an oil change you will be ok repeatedly mix and match i have seen oils turn to jelly but that is normally if you mix straight grads and multi grades in a diesel
