Author Topic: 350 Twin reassembly...  (Read 1475 times)
Offline SClay115
« on: August 24, 2007, 02:17:20 PM »
Do you guys use anything to coat the gaskets on reassembly? Seems like the side cover gaskets and such, the material just seems a little flimsy to hold the oil in. That's just my thoughts, any suggestions? I've seen the HG with the copper coating, but what about the others?
Steve
chrisf
Re: 350 Twin reassembly...
« Reply #1 on: August 24, 2007, 07:05:41 PM »
I was worried about he same thing. I put a thin coat of Hylomar on each surface.
--Chris
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: August 24, 2007, 07:31:29 PM »
It's not a 350 twin, but I have never had a leak with any of the side cover, or for that matter, the oil pan gasket on my 750. Mounted them dry.
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #3 on: August 24, 2007, 08:08:05 PM »
I think the whole point is to fill the imperfections of the two mating surfaces. The pressure crushes the gasket to fill the form. I know certian gaskets call for it, others dont. I was told on triumphs and hondas coating could be trouble.
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline Raul CB750K1
« Reply #4 on: August 25, 2007, 09:31:59 AM »
I second that. In any case, and following Bryan Jones advice, I just "paint" the gaskets with a brush and regular motor oil. It's a little messy, but my CB350 engine seems to hold the oil tight until now.
« Reply #5 on: August 30, 2007, 10:18:13 AM »
ANY gasket goo on the cam bearings is a distinct NO NO
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #6 on: August 31, 2007, 01:45:23 PM »
My methods are;
head gaskets always totally dry, other gaskets use a thin smear of grease on both surfaces, much the same idea as Raul, it allows the gasket to move easily as you tighten to do its job of sealing, 'O' rings either grease again or a little Hylomar.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
