I'm losing a little steam on my latest efforts, so I figured I'd take a night off and post some progress. Fear of public humiliation should keep me motivated now. On the Gulf Coast, it makes more sense to take on summer projects as the heat, humidity and daily thunderstorms make riding miserable.
Here's what's done so far:
-Replaced fork seals with oem
-Fresh 15W oil (worried it might be too stiff - I'll find out)
-Billet preload adjusters from TTR400
-Smoothed and polished top clamp and modified to fit the small electronic tach.
-Re-worked my home-made headlight brackets
-Cleaned up some wiring
-Epoxy painted fork lowers, lower triple
-Re-finished switch housings
-Greased and polished brake caliper arm
-Mounted new low-profile master cylinder
-A bunch of little stuff
Left to do:
-Lace alloy rims to stock hubs. A custom Buchanan spoke kit is on the way...I've got my fingers crossed on this one because I'm not sure what hub the front rim is drilled for. It was too cheap to pass up though. Judging by it's size, I'm assuming it's for the rear of a 125cc dirt bike with a disk hub and that I can make it work. The rear is a shouldered Akront that was drilled for a drum hub very similar to mine. It was pretty nasty looking, but I re-finished it to look good from 5 feet away. I may regret starting this later, but I really wanted to lighten up the wheels.
-Install new surface-ground, cross drilled rotor and new pads
-POR-15 and paint that extra tank I bought about 3 years ago
-Finish wiring
-Re-paint exhaust
-Finish trimming off a few tabs on the frame
-Remove tachometer gear and install plug
-New front tire in proper size
-Keep looking for an aluminum swingarm that will work
I'll keep this going as I finish tasks...and probably discover new ones.
