Author Topic: Replacing Display Lights?  (Read 1351 times)
Justin
« on: July 11, 2005, 10:25:25 AM »
I don't have the bike here with me right now, and it may turn out to be quite simple, but is replacing the display lights (speedo, tach, one turn signal, and oil pressure are out on mine) a pretty straightforward procedure?
eldar
Re: Replacing Display Lights?
« Reply #1 on: July 11, 2005, 10:47:45 AM »
without knowing which bike you have I can only guess. I have a 78K model anf the lights are easy to replace. The unit that houses the lights has three screws. Remove those and the cover comes off. This allows the bulbs to be replaced. If you have an earlier model, the housing is a different shape but should work about the same.
Offline kghost
« Reply #2 on: July 11, 2005, 10:48:50 AM »
What Bike?
On the early 750's thier in the speedo, Later on the bar mount (Oil, Turn).
The hard part is not messing up the old rubber grommets.
Stranger in a strange land
Justin
« Reply #3 on: July 11, 2005, 11:00:06 AM »
Sorry.
'75 CB400F.
