Author Topic: one spark plug stuck  (Read 6074 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: September 04, 2007, 01:47:36 PM »
changed 3 of the four spark plugs last one wont budge....anything I could use or any tips has anyone ran into this before.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline greenjeans
  • 1972 CB750K2
Re: one spark plug stuck
« Reply #1 on: September 04, 2007, 02:10:46 PM »
got this off the tips section and it worked for me....
acetone mixed with ATF fluid.  soaked it for a day or so, heated the block with a heat gun and it cam right out.... Even worked on the stuck piston.   I had originally tried WD-40, PB Blaster and other stuff to no avail.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #2 on: September 04, 2007, 02:18:31 PM »
Greenjeans idea sounds the best, but I've had good luck with PB Blaster. but even with PB I had to let it soak for one or two days.
(http://www.blasterchemical.com/store/moreinfo.cfm?Product_ID=1)
 Matt.
Gallery at:
Offline Rsnip988
« Reply #3 on: September 04, 2007, 02:21:22 PM »
will marvel mystery oil not work if you let it soak in?
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #4 on: September 04, 2007, 02:24:34 PM »
never tried marvel myself, but I know PB Blaster puts all other penatrators to shame.  :)
Gallery at:
Offline mcpuffett
« Reply #5 on: September 04, 2007, 02:25:17 PM »
Does the bike run? if yes try getting the engine warm/hot and try again it may work? cheers mick.
johnny-from-bel
« Reply #6 on: September 04, 2007, 02:49:53 PM »
Pneumatic impact wrench + wd40+ heat+patience. I have gotten everything lose and havn't stript a bolt since I have the PIW.
I case you do not have one. Use WD40 or any of the products mentioned above and a crate of beer. Apply heat. Put the wrench on the plug. Apply some torque not much. Then gently tap the top of the plug. Stop after a few minutes let it cool down. Here is where you have a beer. Repeat the procedure  (WD40 +Heat+ torque+tap) until you run out of beer. Try again the next day
Be patient it may (will) take a few days before it will budge.
« Reply #7 on: September 04, 2007, 07:15:11 PM »
The acetone/atf works the best and I would use it first, then follow up with PB or whatever you want and let it sit. Haste makes helicoil!
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #8 on: September 04, 2007, 07:39:25 PM »
My horror story... My current 78 F project had a broken spark plug stuck in one cylinder. I really had no experience with this. Just never had to deal with it. Anyway I went after it.  The plug itself was broken off. The threads is all that remained in the cylinder.
I first tried to jam a screw driver in it and turn. Quickly I discovered this was not going to get it. I went to the local hardware store to buy an easy out. First I applied liberal amounts of WD-40... Then applied heat with a torch... Lightly hammered the easy out in. Then used a small wrench to try and turn it out. It wouldn't budge!
This is where I make the bad decision... I decide I need more leverage. So I put an 18 in. pipe on it and I immediately snapped the easy out. The problem is. Now the hardened steel was broken off inside the spark plug threads.  Much hammering and I can't remove the hardened steel..   I'm hosed!!!!
Well I took it to work. We have a machine shop. They used an EDM machine to cut out the hardened steel. So I'm back with the head with the original spark plug threads stuck in the head... I now make a good decision. I decide to measure the inside thread diameter of a sparkplug hole and select a drill bit about .020 smaller. I drill right down the middle of that puppy and then pick the threads out. It's all looking good until I make another bad decision. I decide to remove the intake spigots for no other reason than to clean them up...  The spigot breaks..... Geesss...
That head is now in the trash...
Good luck?
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
tbone
« Reply #9 on: September 04, 2007, 08:03:01 PM »
Do Not Use a Pneumatic Impact Wrench!
Snap off the hex section of the plug and you've just added to your problem.
Plenty of oil, heat and a whole lot of patience. Gentile pressure, if it moves go back and forth extending the travel a little with each change in direction.
Once it's finally out spend a few bucks on a thread chaser before installing another plug.
johnny-from-bel
« Reply #10 on: September 04, 2007, 10:20:12 PM »
I beg to differ. The torque on the impact wrench is so low (in fact you can hold it still by pinchin it with two fingers) it will never snap off the hex section. It is the constant hammering that does the work.
tbone
« Reply #11 on: September 05, 2007, 03:01:09 AM »
And some pneumatic impact wrenches have sufficient torque to snap a rear axle on a CB750!
johnny-from-bel
« Reply #12 on: September 05, 2007, 04:28:33 AM »
Suffice to use one like I have with adjustable torque
