Author Topic: carb slow jet stub removal?  (Read 1514 times)
Offline Rsnip988
« on: September 05, 2007, 07:45:20 AM »
76 cb750 k
any idea of a way to get out or drill out gently a slow jet that broke off in the hole
(i overtightened it i guess)
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Re: carb slow jet stub removal?
« Reply #1 on: September 05, 2007, 08:06:09 AM »
I bought some 550 Carbs on eBay that this happened to.  I took a narrow flat blade screw driver and tapped it into the soft brass.  Just enough to get a bite.  It screwed right out.
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: September 05, 2007, 08:15:48 AM »
   Found out the hard way that drilling isn't good. The clockwise rotation of the bit just screws the stub deeper in the hole.
Offline Jonesy
  • Shop Rat
« Reply #3 on: September 05, 2007, 09:02:15 AM »
...unless you have left-handed screw extraction drills...
Offline scondon
« Reply #4 on: September 05, 2007, 09:35:40 AM »
  Good point.  I couldn't find one small enough at my local stores, and being the impatient type decided to turn a few day setback into a two week one... ;)
Offline Rsnip988
« Reply #5 on: September 05, 2007, 10:47:00 AM »
excellent advice and ideas gentlemen, I shall let you know which works
RKS
R.K.S.
1976 CB750 K6 Full
