Well... I drove up to Huntsville today and picked up the new project bike. Here is a link:
http://huntsville.craigslist.org/mcy/416791862.htmlThe bike fires right up and runs pretty good. After some negotiation I left with the bike on the trailer, and my wallet only $400 lighter. I will have more pictures as I start to work on things. Even though I'm pretty mechanically inclined and am pretty handy with a wrench, I am still a newcomer to the Honda fours. So I will be depending heavily on you guys and the archives of this group to help me out.
I gave the bike a good once over and there are several things that are a plus on a $400 bike:
1. It starts and runs good.
2. The rims can be polished up and will look nice.
3. The exhaust is in excellent condition and appears to be a decent aftermarket 4 into 2 system.
4. The tires only have a few hundred miles on them and are like new.
5. It has the sissy bar and luggage rack that I can maybe sell for a little bit of money.
6. It comes with 2 carb rebuild kits, new fork seals, new oil filter, original mirrors, original horn, and the original manual.
7. All electrical and gauges work correctly.
A few things I noticed that will need to be addressed soon:
1. One of the carbs appears to be leaking through a vent tube when the fuel petcock is left on. The P.O. said that he rebuilt the carbs, so do you guys think I need to go back through them again.
2. The ignition switch is kind of temperamental and is mounted up by the gauges. I may need to rewire this.
3. The side cases are some cheap ass aftermarket stuff and already starting to crack where they bolt on.
4. The gas tank has a horrible paint job on it and is missing the badges and is a little rusty on the inside.
Anyway... That's about all I can think of right now.
Since it is running, I will probably start by checking the compression, and making sure the brakes and other safety stuff is up to par. Next I will start to mock up stuff like the seat and so forth and see just how I want everything to come together. Once everything is the way I like it, then everything will be dismantled and either ground, smoothed, cleaned, polished, and/or painted and then re-assembled into my own little custom cafe racer.
Stay tuned...
Regards,
Irish Guy
