Well... I got some more stuff done...
I took off the seat cover and all of the snaps. I took my Dremel and very slowly cut a couple of relief cuts so the seat would clear where I chose to mount my rear turn signals. I also took it over to my drill press and drilled matching holes in the seat pan for the OEM rubber stand-offs that rest on the frame. I wanted to use the OEM hinge and locking mechanism, but that ain't happening. The seat is much narrower than the stock seat. So what I have decided to do is to buy some of the little clamps that you can use to attach a broom or mop to the wall and mount them along with the OEM rubber bumpers to the bottome of the seat and this way the seat will sort of snap on and snap off the frame. It won't be locking , but it will come off and go back on with a minimal hassle. By the way... This seat from
www.hotwingglass.com is very well constructed. I am very happy with it. For $175 it would be difficult for me to make a nice fiberglass seat, and have it padded and covered for that kind of money and it look half as good.
Next I went ahead with my very limited bodywork experience and put a few applications of the finishing cream on the small imperfections in the tank. I need to sand it one more time and it will be ready for more primer and then paint.
Next I re-sanded all of the plastic and fiberglass parts. I couldn't find any special primer for plastic even after trips to several stores. I finally settled for Bulldog adhesion promoter. I says to use two light coats. I did that and then painted three very light coats with some Rustoleum semi-gloss black. Enough to know that I don't think I want to paint this color. I will act as a good fill-in once I wet sand everything down again. I am still undecided about the color. But I will probably go with gloss black and the clear coat it.
I also played around a little with the left side dyno cover. I hit it with a stainless wire brush. I stripped it good and left it nice and shiny, but it also left some pretty nice scratches in it. These will take some serious sanding to get out. I don't think I will try that again. The old adage is to start with the least abrasive method that you can get by with is good advice here.
Anyway... Here are some pictures for your viewing enjoyment...
