Author Topic: Tail light problem.........  (Read 1092 times)
Offline mmtsquid
« on: September 14, 2007, 07:51:20 AM »
77 CB 550K, brake light works just fine, but the "running light" doesn't burn.
The bulb is in good shape.
I'm not much on the electrical stuff - can anyone help?
77 CB550K4
Offline Gordon
  • 750K1, 550K2
Re: Tail light problem.........
« Reply #1 on: September 14, 2007, 08:09:40 AM »
Did this just happen or has it been like that for a long time?  Are you positive that the filament for the running light hasn't burned out?
Offline mmtsquid
« Reply #2 on: September 14, 2007, 08:15:10 AM »
It's a fairly recent happening, as I KNOW it worked a month ago.
I was riding home from school last night when a guy at a stoplight told me it was out.
Sure enough, it was.
Fuses are good, and I know the bulb is good as I "reversed" the bulb and hit the brakes - the small filament came on then.
But the bulb back in correctly, hit the brakes, and the "bright" filament was lit.
I haven't made any changes to anything, so I'm kind of stumped.
77 CB550K4
« Reply #3 on: September 14, 2007, 08:21:59 AM »
Chase the brown wires/ connections.
Offline cleveland
« Reply #4 on: September 14, 2007, 08:29:45 AM »
Yep!  Mine came unplugged under the seat.  Took 3 to 6 seconds to fix.
Offline mmtsquid
« Reply #5 on: September 14, 2007, 08:31:00 AM »
the connections under the seat I've already checked - guess I have to go deeper!
77 CB550K4
