Author Topic: Latest photos of my CB750f with motogadget tach and new forks/brakes  (Read 4854 times)
Offline 750essess
  • Orleans Cycle Repair & Resto
these where requested on another thread. Thought i would start a new one, so I wouldn't look like a high jacker.
836 cc with JE 10 to 1 pistons
kickstart delete
alodined engine covers covers
web cam
mild port
stock carbs with pods
125 mains needle one clip down
2004 cbr600f4i forks, trees, brakes, clip ons and controls
hel lines
holeshot performance 43mm headlight brackets
cb919 windshield kit
custom wiring harness
motogadget instrument, with tach, speedo, oil pressure, volts
IKON shocks
rearset from a yamaha fz1000 I think, not sure
 ;D
« Last Edit: September 14, 2007, 06:08:09 AM by 750essess »
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline rugger81
Re: Latest photos of my CB750f with motogadget tach and new forks/brakes
« Reply #1 on: September 14, 2007, 06:09:20 AM »
Nice!  very clean looking.  Is there a good writeup out there anywhere for the cbr600 fork swap?
'77 CB750K - Rebuild Project Page
'15 Moto Guzzi Griso
Offline 750essess
« Reply #2 on: September 14, 2007, 06:26:57 AM »
yes, there have been a few posts on the subject.
76CB750F
69Z50
XR650L
Offline maksuttt
« Reply #3 on: September 14, 2007, 07:08:59 AM »
Good work! Looks solid.
CB-750F 1975
My gallery is here
My blog is here
memphis3724
« Reply #4 on: September 14, 2007, 08:04:07 AM »
Wow... I really love the tach/speedo! The pricetag is a little steep though. Nice work!
Offline 750essess
« Reply #5 on: September 14, 2007, 08:34:34 AM »
Yeah i know... thats what credit cards are for right ? lol :D
76CB750F
69Z50
XR650L
Offline DCopp
« Reply #6 on: September 14, 2007, 10:22:16 AM »
i'm pretty sure an '04 F4i had usd forks...might wanna check.
Offline 750essess
« Reply #7 on: September 14, 2007, 11:11:33 AM »
Well thats what i was told by the guy who sold them to me. I looked it up on hondaparts direct and they only show a 2004 f4, no separate diagram for the f4i so I guess they where the same fork. EDIT: found a pic it is conventional fork.
« Last Edit: September 14, 2007, 11:22:42 AM by 750essess »
76CB750F
69Z50
XR650L
Offline smccloud
    • Shaun's blog
« Reply #8 on: September 14, 2007, 04:53:00 PM »
i'm wondering what you used for the rear disc.  i have seen one conversion, but i cannot remember where right now.  i have everything but the adapter to go from drum to disc for mine, even if it is from a yamaha.
CB750 K2
Quote from: Hush
Who needs a mobility scooter when you've got a SOHC4?
Gun/Cars/Motorcycles/Computers/Insert Next Expensive Hobby here
« Reply #9 on: September 14, 2007, 09:12:18 PM »
Good job.... suspension upgrade, improved handling, better braking, lighter weight. What else is there to say??
Offline KB02
« Reply #10 on: September 15, 2007, 05:44:25 AM »
The rear looks stock. The F's had the rear disk rather than drum. Cycle-X had a drum to disk conversion, but make sure your finances are in order before even looking at it...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline UnCrash
  • Pass
    • My Blog
« Reply #11 on: September 15, 2007, 06:42:53 AM »
That's one badass F!   It puts the FU in FUN!  ;D ;D
Offline smccloud
    • Shaun's blog
« Reply #12 on: September 15, 2007, 06:58:44 AM »
maybe i will scour the junk yard then............
on another note, how is their big bore kit?
CB750 K2
Quote from: Hush
Offline cben750f0
« Reply #13 on: September 15, 2007, 02:56:54 PM »
yep those are F4i forks,
here's mine...
man that is an awesome F m8, how do you have a register on the adapter plates to get the discs to rung true?, was just wondering, also how much room to you have to the spokes from the calipers?... looks bloody tight!!! LOL
You have made me go and have a look at the wreckers!!!!!  ;D
keep us in the loop..
peace
« Last Edit: September 15, 2007, 03:03:55 PM by cben750f1 »
ScottB
« Reply #14 on: September 15, 2007, 10:56:52 PM »
750essess:
How did you arrange the spacers for either side of the wheel?  It is difficult to tell if you are even using any from the pictures but that can't be.  Did you have to machine new ones?  What did you make them out of?  This is the latest challenge I am having with my conversion.  Also - headlight ears and rear sets.  My 900 forks are 45mm; would the ones you have work in my situation?  What are they from?  Rear Sets - did you weld bolts to the frame, tap the frame or run bolts through?  Bike looks clean!
« Last Edit: September 15, 2007, 11:15:45 PM by ScottB »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #15 on: September 16, 2007, 09:44:08 AM »
Curious about the steertube. Did you have to swap out the tube with the CB750 unit?
Offline aj
  • no better way than goin cafe.
« Reply #16 on: September 16, 2007, 07:18:55 PM »
bad ass bike! i love it. ;D
Offline 750essess
« Reply #17 on: September 17, 2007, 06:24:20 AM »
the back is stock.
there are spacers to adapt the disk to the wheel and space them correctly. Sorry but I didnt take measurements, had a local machine shop make them up out of aluminum. There isn't much space between the spokes and the caliper (about 2mm) I was worried about this but nothing has rubbed yet. When I had him make the axle, I had him incorporate the axle spacers into it. It threads together like the stock one.
The steering tube is the one from the 600 but pushed up about 5mm and re-welded.
The rearsets I mounted by drilling a hole through the frame, then I put in a bolt with a nut and welded on both sides. If i where to do this again, I would drill and put a tube in and weld, like the stock mount points are. I'm not sure what they are from. Got them from a junk yard, I think yamaha fz1000 sets.
I dont see why the 900 fork won't work too.
Also note that I didnt set this up for a speedo cable. This is one reason why I went with the motogadget set up. Im not saying it would be impossible to use the mechanical speedo though.
Also a note about the handling. It steers a little quicker and of course rides much metter. The brakes work like a 600cc bike. I have one issue though and that is I have a little wobble going into high speed turns (over 80mph) that I am currently working on. Im going to install the bigger axle from the 600. I also found the spokes and steering stem bearings had loosened up on me. Haven't had a chance to ride it yet to see if has improved.
« Last Edit: September 17, 2007, 06:27:02 AM by 750essess »
76CB750F
69Z50
XR650L
Offline capnspif
  • Garage: Buncha Honda's & a Duc
    • Photos
« Reply #18 on: September 21, 2007, 08:37:39 AM »
Looks great, nice work indeed!
Offline 750essess
« Reply #19 on: September 21, 2007, 10:41:38 AM »
Thanks everybody for the compliments  ;D Capnspif, how does yours handle? Im still having a problem at higher speeds in turns, doesnt feel like your gonna get spit off or anything, feels like something is flexing for sure.
« Last Edit: September 21, 2007, 10:44:10 AM by 750essess »
76CB750F
69Z50
XR650L
Offline motomotard
    • GoGo Garage
« Reply #20 on: September 21, 2007, 11:54:33 AM »
wow, i gots to get me a front end like that
Offline capnspif
    • Photos
« Reply #21 on: September 21, 2007, 12:20:39 PM »
I haven't been over 60 or so yet. I just got mine on the road and am still dialing in the carbs and suspension settings, plus it's got new tires. Still, it's amazing how quickly it wants to turn - I've got the @ss end of the bike pointing at the sky so it's not a surprise.  :D
Offline 750essess
« Reply #22 on: September 24, 2007, 05:27:28 AM »
Mine handles great until 75 or so. Could you post some pics of your rear swingarm setup and what its from etc.
76CB750F
69Z50
XR650L
Offline capnspif
    • Photos
« Reply #23 on: September 27, 2007, 09:09:59 PM »
I've got pics through my gallery link in my profile. The swingarm, wheel and brakes are from a cbr600f3.
Offline 750essess
« Reply #24 on: September 28, 2007, 05:04:22 AM »
Thanks, looks great. Might have to do that swingarm conversion this winter. I ended up at at 125 mains and the needle all the way up on mine, pulls very linear all the way to the top. I have the preload about half way and the compression and rebound in the middle.
76CB750F
69Z50
XR650L
