Author Topic: DEA8-L  (Read 1840 times)
Offline donny
DEA8-L
« on: September 15, 2007, 10:35:01 AM »
 ;D I was going through the Honda Service bulletins, #27 says; for in town fouling, install D-8ES-L. My Honda guy never heard of it. What would it be sold as today?
Don
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline spitfire
Re: DEA8-L
« Reply #1 on: September 15, 2007, 10:55:50 AM »
Ther is a thread somewhere on this forum, think D8EA are the ones to go for.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline Jonesy
  • Shop Rat
Re: DEA8-L
« Reply #2 on: September 15, 2007, 12:15:38 PM »
D8EA is the standard plug. The D8EA-L has an extended tip electrode. (D8ES was the older numbering system)
Re: DEA8-L
« Reply #3 on: September 15, 2007, 03:49:20 PM »
The closest match to that plug today is the ND X22ES-u. This plug is approximately a "D7.4E" heatrange, where the extended-tip "-L" series plugs ran at D7 temps on their tips, with D8 heatsinking in their seals. The ND plug has a thinner, more extended tip, similar to the "-L" plugs.
I normally run the X24ES-u with regular gas on the highway (midgrade with heavy loads) and the X22ES-U on midgrade for commuting work, when there's lots of idling going on, to keep the plugs cleaner. In cold weather commuting, I use the X22 with regular gas to make it warmer and cleaner.
The D8E series is too cold for lots of idling (it fouls after 1000 miles or so), the D7E series too hot for highway use. Honda specifically asked NGK for this plug, in 1970.
The "-L" disappeared from NGK production in the mid 1990s. I miss that plug.  :(
Offline donny
Re: DEA8-L
« Reply #4 on: September 16, 2007, 09:07:01 AM »
 ;D ;D..thanks a bunch.... ;D
Don
Offline spitfire
Re: DEA8-L
« Reply #5 on: September 16, 2007, 10:32:11 AM »
Thanks for that, I ordered plugs for the bike and recieved DR8ES-L (R for resistor), which kept fouling then I read a thread on this forum which recommended D8EA's so I fitted them, they worked much better, have just ordered some ND X22ES-U's so hopefully they will work even better.
Cheers
Den
Wirral UK
