Author Topic: Dyna 2000 rev limiter?  (Read 4516 times)
Offline scondon
  • Mmmm......tasty bugs
« on: September 17, 2007, 10:12:00 AM »
  I have a mini speedo and tach fitted and the tach has been pretty accurate up to 6000rpm so far. I went on a "tear-ass" ride yesterday and had the needle hit 10,000rpm on a few occasions. My rev limiter is set at 9000rpm so either my tach or my limiter is not functioning properly.
   I don't recall reading anything in the Dyna 2000 set-up regarding having to do anything special to get the rev limiter working, just set it at desired setting. I do not have the digital tach wires hooked to anything and don't suspect I need to in order to have the limiter work.
   I suspect that my tach cable may need some generous lubing and/or my mini tach is not suited for high rpm reads. Just wanted to post here in case anyone has any insight. Don't want to blow the motor trying to test the limiter ;)
Offline dusterdude
Re: Dyna 2000 rev limiter?
« Reply #1 on: September 17, 2007, 10:36:44 AM »
sean,set the limiter at its lowest limit and see if it works there.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline scondon
« Reply #2 on: September 17, 2007, 10:55:35 AM »
 8500rpm is the lowest setting. I'll set it there and see if I can trip it on the way home ;) :)
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #3 on: September 17, 2007, 11:27:23 AM »
Sean, I bought NOS speedo and tack for mine and the Dyna works perfectly. Before installing the Carillos I had it set to 8,500 (min) and it did the perfect stutter. I've since had it set to 10,500 and again - it's dead on with the tach. The engine doesn't die - it just stutters and will not gain rpm. The bike will go flat and quit pulling. In order to keep fuel building up in the ports, they fire each pair alternately - much like my car's MSD A6 "soft-rev" system. The Dyna is the cake. Even when I've hit a false netural, the tach will keep up. I've seen the tach quickly swing up and hit at the set rpm at the same instant the rev control kicks-in. Your suspecting the tach is likely a good start.
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline scondon
« Reply #4 on: September 17, 2007, 11:39:04 AM »
  Thanks for the detailed response, Gordon. Good to know what to expect when I hit the limit :)   I'll give it a go in second gear on the way home tonight and post the results here. when my tach showed 10,000 I was looking down at it 'cause my ear told me I was at, or around stock F2 redline.I'm fairly certain that I can tell by ear if I'm revving way past 8500rpm so I'll spin it up and see if I can get it to go "flat" ;)
Offline dusterdude
« Reply #5 on: September 17, 2007, 01:09:31 PM »
good god!!!
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline scondon
« Reply #6 on: September 17, 2007, 07:07:17 PM »
 WooHoo!  Set the limiter at 8500 and the engine went flat at an indicated..........10,500rpm.
  If I ever go deaf from the unbaffled Kerker, this tach will at least be good for telling me if my engine is running or not :)
« Reply #7 on: September 17, 2007, 07:09:11 PM »
.....I told you about those gauges Sean. ;)
« Reply #8 on: September 17, 2007, 07:28:07 PM »
Those mini-guages sound like crap Sean, send 'em to me and I'll smash em up for you! (pack them carefully though.................)  :D
Offline scondon
« Reply #9 on: September 17, 2007, 08:28:54 PM »
  That you did :)  They work OK for sensible riding (read just over 5000rpm at 80mph in 5th) and look pretty neat, but as a redline indicator they are worthless. Unless you are really, really good at doing conversion calculations at 70mph in 2nd gear while picking out your line through the next turn ;)
   I've been thinkin' about shipping ya my dirty clothes, just to keep my shipping skills fresh :D :D    USA Ebay wrote and said they miss ya somethin' awful ;) ;D
« Reply #10 on: September 17, 2007, 08:30:23 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline mrbreeze
  • Not your average
« Reply #11 on: September 17, 2007, 11:37:59 PM »
Listen to what Terry is telling you Sean........pack those gauges very,very well with plenty of good packing material cause he can smash em' up better when they are in good shape to start with!!!!!!!..................(You guys are killin' me!!!!!!!!)
MEMBER # 257
« Reply #12 on: September 18, 2007, 04:43:08 AM »
Sean,
I've got a nice set of K4 gauges that I took apart and applied the white ground/black letters on for my 836. I later decided not to use them and went for NOS and their stock appearance (the more I did on the inside of the motor, the more I wanted the outside to look stock).
You are welcome to these for what I have in them which is about $100.
Regards,
Gordon
Offline scondon
« Reply #13 on: September 18, 2007, 08:41:39 AM »
  Thanks very much indeed for the offer,Gordon :) The front end has been changed a bit on my bike and I no longer have room for stock gauges and bracket due to the headlight shell being closer to the triple trees(speedo/tach cable would have to bend a lot to get around it).
When I take the bike in for Dyno next month I'll see what actual rpm I'm at when the mini tach is reading its max 12,000 and see if it's worth keeping. My plan has always been to use these cheap gauges until I could find a digi tach and mechanical speedo that look good together :)
    Hitting the limitier was just like you said, Gordon. Pretty neat, in fact. The tach needle shot up and then stopped solid as if a pin were stuck through it. The bike didn't stumble or make any explosive exhaust sounds, it just held at that rpm until I let off the throttle ;D
« Reply #14 on: September 18, 2007, 11:59:05 AM »
It's cool to hear it happen on the dyno too. ;D
« Reply #15 on: September 18, 2007, 02:15:58 PM »
Hmmmnnn, dirty clothes eh? Well you and I are about the same shape and size Sean, and I can definately use some more Levi's and T Shirts, so no worries mate, send 'em out!
Hey, what's yer shoe size? I need some cowboy boots to go with my new chaps, apparently they're "de-riguer" for motorcycle riding in the states, so I'm gonna start a fashion trend here! Should be good in summer too, as apparently you don't need to wear pants?
I'm still keeping Mr Ebay's kids in private school too, but luckily for us both, nowadays sellers seem more willing to ship direct to Oz, and because the Oz dollar is up against the greenback, it's a tad more affordable too, for this ol' pensioner! Have a good one mate, Cheers, Terry.
Offline scondon
« Reply #16 on: September 18, 2007, 03:03:24 PM »
    No worries, mate. I should have some size 13, extra wide "#$%*kickers" left over from my line dancing days that oughta go nice with those chaps. Speaking of chaps, I was going to send ya some for Christmas but it sounds like I'll be sending the colored bandana collection instead. The collection does not come with a manual so you'll have to figure which pocket, left or right, to stick'em in through trial and error.
    We'll also have to get you a bad-ass nickname to go with the new look. My vote is for "Three Dollar Bill", as in "Queer as a........................." :D :D :D :D
  Hope your Spring has sprung and that the sun is once again shinin' on the good riding roads ;D
« Reply #17 on: September 19, 2007, 02:04:04 AM »
Hey thanks mate, I'll look forward to receiving those bad boys, size 13 is just the right size too, hows that for coincidence?
Well I gotta go get me a pile cushion, I had a lot to drink at a new bar in the city last night and I woke up face down in a cheap hotel room?
I must have made out alright with the ladies (although I don't remember seeing any) because the floor was strewn with used condoms, (I even had one in my mouth, ha ha!) but I'm not drinking any more of that particular brand of beer, geez it makes my asss hurt, ha ha! Cheers, Three Dollar Terry.
Offline scondon
« Reply #18 on: September 19, 2007, 09:36:43 AM »
 :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
   You slay me, Terry. Hold on to those used condoms. I hear they're great for stopping up a leaky Pingle ;) ;D
« Reply #19 on: September 19, 2007, 09:47:48 AM »
Terry,
Did you star in Broke Back Mountain?
We need to quit talking abouy Terry and chaps. I certainly hope he is wearing his Levis with his chaps. That sounds really nasty.
Check your email for a joke I sent. Post it if you feel it's appropriate.
« Reply #20 on: September 19, 2007, 09:50:09 AM »
Sean,
Looking forward to your dyno results. These 750s sound/scream really nice over 10K. Mine doesn't go below 10K in first or second. It happens too damn fast once the cam comes on and I can't help myself.
« Last Edit: September 19, 2007, 09:53:21 AM by RxmanGriff »
Offline scondon
« Reply #21 on: September 19, 2007, 10:46:05 AM »
Sean,
   Aint that the truth ;)  Now that the limiter is tested I've set it back up to 9500. The few times I've asked Mike about what redline I can expect from my components he'll say "9700" without batting an eye. When talk goes beyond that it's straight to the stock F2 rod bolts as being the weakest link. The balanced/lightened crankshaft and CR carbs have the motor running so smooth at high rpm's that I'm willing to cheat up a few hundred to 10,000. When it goes to Dyno I'll set the limiter to 10,500 and ask them to run it to a solid 10,000 :)
    When I had my other bike dyno'ed I ran it to 10,000. Same stock F2 rods, but not near the amount of motor work that the new bike has. When it got above 9000 the Kerker w/ med. competiton baffle was spitting out a sweet, four cylinder symphony. Can't wait to hear that tune again ;) ;D
« Reply #22 on: September 19, 2007, 11:45:39 AM »
10K with stock rods for 20K+ miles. My weak link when I blew it was the valve. Damn stock springs don't like going past 10K! Try not to miss 2nd gear.
Offline scondon
« Reply #23 on: September 19, 2007, 12:09:49 PM »
   Glad to hear that, Rxman :)  With me on the bike at 90mph I tend to err on the side of caution. Standing next to the dyno, sippin' coffee and shootin' the #$%* is when I become fearless :D
    APE put a 14,000rpm stamp of approval on the crank. Mike is hesitant to give me the "green light" on the head he built for me, litigation being what it is these days(haha), but I'm sure it's good to 11,000. If I am satisfied with the tune on the CR's when we get it hooked up then I may just spin 10,500 and see if anything blows. Or not, we'll see ;D
« Reply #24 on: September 19, 2007, 12:33:25 PM »
I'm not worried about the springs as they are Kibblewhite as are the retainers. If you set the limiter to 10,500 I guarantee the dyno operator will go to 10,500 Sean. Set it to 10,000. I'd be very surprised to see it making power over that figure. Many times we think the engine is making power in the 11,000 range because od tach error. The Dyno will show what's really happening
« Last Edit: September 19, 2007, 12:36:08 PM by MRieck »
