Author Topic: CB750, Went to change oil for first time and found this  (Read 9097 times)
Offline KB02
Re: CB750, Went to change oil for first time and found this
« Reply #25 on: September 20, 2007, 05:06:13 AM »
I just did a quick search on evilbay for "oil pan CB750. Here's what I've found:
eBay Auction #1:
Honda CB750 CB 750 SOHC Engine Oil Pan
eBay Auction #2:
Honda CB750 CB 750 Oil Pan
Hope it at least some what helpful.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #26 on: September 20, 2007, 05:52:46 AM »
 Drill through the drain bolt and tap it for a 8mm bolt. Put a copper crush washer under the bolt. That's the cheapest thing I can think of.
Offline GNXFan
« Reply #27 on: September 20, 2007, 11:15:16 AM »
I have a 73 K3 oil pan if you want to change out the whole pan.
Offline turboguzzi
« Reply #28 on: September 20, 2007, 12:46:59 PM »
don't want to aggravate, but what's even more serious is: when was the last time the guy changed the oil?
Wouldn't be a bad idea to pull the valve cover off and see how's the cam like, it's among the first things to suffer from bad oil an relatively, easy to access.
Dont ask me how I know please....
make sure you put there the best oil that you can get at least.
Offline dusterdude
« Reply #29 on: September 20, 2007, 01:03:35 PM »
or tap it 1/8 inch pipe
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
johnny-from-bel
« Reply #30 on: September 20, 2007, 01:12:40 PM »
If it was mine. Id put the pan in my workshop oven put it on 350 degrees celcius for a few hours. The scrape the JB weld of patch it up with wax and sancast myself a new one
Offline firecracker
  • At being Shameless, I'm an
« Reply #31 on: September 20, 2007, 01:28:04 PM »
What kind of oil do you recommend?
 ;D
Life is like a game of cards.  The hand you are dealt represents determinism.  The way you play it is free will.
  -  Jawaharal Nehru
Offline dusterdude
« Reply #32 on: September 20, 2007, 01:29:17 PM »
 ;D
oh #$%*
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline turboguzzi
« Reply #33 on: September 20, 2007, 02:25:31 PM »
 ;D
oh #$%*
oh #$%* indeed..... don't want to kidnap this thread + there are tons of oil threads in sohc4 + what I can get in Italy is not necessarily available in the US and viceversa.
enough said :-)
Offline Gordon
  • 750K1, 550K2
« Reply #34 on: September 20, 2007, 03:26:01 PM »
You must not own a 750, then. ;) ;D
« Reply #35 on: September 20, 2007, 05:45:27 PM »
 ;D
Slippery stuff.
« Reply #36 on: September 20, 2007, 05:49:59 PM »
Oh Boy, oil and guns are the hot buttons here. Should take us through the winter.
Offline cleveland
« Reply #37 on: September 20, 2007, 09:59:11 PM »
$15 shipped is pretty cheap, so that's the way that I would go.
BTW, scanning the gasket is plain genius!
antiq
« Reply #38 on: September 21, 2007, 09:19:02 AM »
 ;D
I'm using Mobil1 synthetic for one of my bikes and Exxon 20-50 in another. Use the best you can afford from a brand you trust. Just be sure it doesn't have extra additives. I forget what they're called just now. Bikes have wet clutches that can be adversly affected by those additives.
Offline Gordon
  • 750K1, 550K2
« Reply #39 on: September 21, 2007, 09:34:28 AM »
Uh-oh!  Someone took the bait!!!! :D
Offline cleveland
« Reply #40 on: September 21, 2007, 10:00:39 AM »
 :D
« Reply #41 on: September 21, 2007, 11:06:01 AM »
Yep
Offline firecracker
« Reply #42 on: September 21, 2007, 11:22:28 AM »
Sorry, I thought this    ;D   was a dead give-away at my intended sarcasm.
I feel so bad, I wanna shoot myself.
What type of gun would you recommend?
 ;D   ;D   ;D
  -  Jawaharal Nehru
« Reply #43 on: September 21, 2007, 11:58:33 AM »
I would suggest a small caliber with a hollow point bullet. This way the undertaker can putty up the hole and you can have the lid open and be properly viewed. Fellows may also wish to come by place a small sprig in there.  ;D
Offline mkramer1121
« Reply #44 on: September 21, 2007, 08:02:58 PM »
He didn't say kill, just shoot....I'm sure a small caliber rifle won't leave too much of a hole in your foot... ;D
Offline mrbreeze
  • Not your average
« Reply #45 on: September 21, 2007, 09:00:46 PM »
 ;D
Oh sh!t!!!!!!!......here we go again!!!!!!!!!!
MEMBER # 257
Offline jtb
  • An unlikely
« Reply #46 on: September 22, 2007, 06:25:56 AM »
Well... It's obvious, if the PO had used decent oil, this would never have happened. ::) ::) ::)
1977 CB750F
1985 V65 Sabre
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #47 on: September 22, 2007, 08:16:04 AM »
Speaking of, did you all see the "expert's" admonition to "Don't use synthetic in any CB750 honda.  The clutch will slip and you'll be wasting your money" published in this month's Classic Bike (page 89)?
I haven't yet gotten around to writing a reply, but maybe we should flood them with responses...
Dave
Offline Gordon
  • 750K1, 550K2
« Reply #48 on: September 22, 2007, 08:18:15 AM »
Meh, not quite contentious enough.  You'd  have to say something like, "if the PO had used synthetic oil, this would never have happened", to really get things going. :D
« Reply #49 on: September 22, 2007, 12:08:30 PM »
Just to keep adding fuel to the fire here is a note forwarded to me from a HD owners group. The spelling is on par for a HD group:
Ken - from P2P - found a Harlely Forum on the net and found out that Harley is no longer suggesting SYN 3 (somewhat synthetic - its a group III)  Mobil 1 , 20W-50 for bikes is a group IV, better oil for less $, but that is not what the fuss is all about.  The SYN 3 oil is too light of a vis for the tranny.  After reading for hours on this forum we came up with - Mobil 1  20W-50 for bikes or Mobil 1 15W-50 for race cars, $20.00 for 4 qts. at Wal Mart.  The only advantage is in the 15W and it gets to the upper parts of the engine sooner and thats where most wear occurs.  It also has less Molly and is less acidick.  We are putting Mobil 1 - 75/90 Gear Oil in the trans.  Makes it last longer and run cooler and quiter.  The reason for Harleys switch is they were getting reports of a lot of metal fillings when changing the trans.  Mobil 1 will stop that.  The forum also agrees that any good cheap dyno oil will do in the primary as it only lubs the chain.  20W-50 non synthetic was suggested.
Read the oil and related topics and make up your own mind.  I suggest a lot of research on this.
Here is the address.       http://www.hdforums.com
Lifes journey is not to go to the grave in a perfectly preserved body.......... but to slide in sideways, totally worn out yelling..........Good God What A Ride!!!!!
Pete
