Author Topic: Trying to mount ignition switch on '73 cb500  (Read 1203 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: September 19, 2007, 04:51:55 PM »
I am nearing completion of my little project rat bike, and I am running into a small problem. I don't know (remember!) where the ignition switch mounts. In fact, I had to by an aftermarket unit from Sirius up in Ontario. I am missing a mounting plate. I assume it mounts to the frame, but the microfiche resources I have access to don't really help as far as showing anything definite.
It doesn't have to be anywhere specific, but I was thinking it would be good on the left side, just below and near the front of the gas tank. Between the bars is probably out. I eliminated the idiot light panel and I don't see anywhere for it to go up there.
Suggestions are more than welcome! Thx
1978 CB750K8; 1970 CB450
Offline Irishguy
Re: Trying to mount ignition switch on '73 cb500
« Reply #1 on: September 19, 2007, 05:34:07 PM »
I will be watching this thread also.  My 1973 ignition switch has been installed up near the handlebars using some kind of 70's aftermarket switch mount.  I want to return it to it's original location.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: September 19, 2007, 07:24:32 PM »
Found this in a 500-550 manual I have on a CD. Hope it helps.
Offline gregwaits
    • waits music
« Reply #3 on: September 19, 2007, 10:11:41 PM »
Thanks Bob. That pic does help.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #4 on: September 19, 2007, 11:28:16 PM »
I had these pictures laying around.  . .hope they help!  (1973 CB500 - obviously modified a bit but switch still in stock location)
The ignition mounts into a metal bracket that's kinda partially a tube that then mounts onto the frame with only one bolt (6mm). In the second picture, you are actually seeing the bracket to the left of the chrome flip up cover - the ignition is mounted inside. Sooorry that description is retarded but I don't have any  pictures of the switch and bracket thingy disassembled!   :P
« Last Edit: September 19, 2007, 11:30:16 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
